2003 4.2 S-Type won't start.
Old Feb 12, 2012 | 05:06 PM
relaxed00's Avatar
Default 2003 4.2 S-Type won't start.
Hi, I have a 2003 4.2 V8 S-Type(none super Chg.) and it won't start. It turns over fine and I also separated the fuel line by the fuel rails to see if it's getting fuel. Fuel pump works fine and gas came out when pump came on. I held open the throttle body to ensure it's getting air while I tried to start it but still nothing. It's not even trying to fire at all. I see no obvious vacuum leaks. I'm only getting one code and that's RL turn signal out. Could someone please shine some light on my issue and give me some ideas. Also the transponder not working and doors won't stay lock with key or automatic lock button. Thx
__________________
Old Feb 12, 2012 | 05:30 PM
JagV8's Avatar
Probably your best bet is to start with the previous threads about this as they go into a lot of detail and have diagnostic PDFs.
Also a PDF or two in the FAQs / TSBs - probably the same ones.
Old Feb 12, 2012 | 06:27 PM
Sumrfun's Avatar
I have a 2005 version with the 4.2L. Please check the primary and secondary fuses for the car concerning engine management.
Old Feb 13, 2012 | 10:34 AM
relaxed00's Avatar
Hi JagV8, i have searched the other threads, but i'm unable to find the "diagnostic PDFs" ---could you please attach a link for me? This morning i have tried a hard reset 4 different times, i checked the fuse box in the trunk, under the hood, and in passenger side kick panel and found all fuses are good. I have also tried turning the ignition forward/back 3Xs in row and then try to crank... still not firing. The computer is not showing any codes.
Old Feb 13, 2012 | 10:46 AM
relaxed00's Avatar
Also I forgot to mention. The transponder for the lock/unlock doesn't work. Could this possibly keep the car in Anti/theft mode and not allow it to fire?
Old Feb 13, 2012 | 01:04 PM
tbird6's Avatar
Yes. It's called PATS (Passive Anti-Theft System). What is the red light mounted in the center of the defroster duct up by the windshield doing?? Report back if it's flashing or solid and what changes when you turn the engine over.
It sounds like the PATS has immobilized the car. Be aware it might require a dealer to reset everything and get your keys programmed correctly.
Old Feb 13, 2012 | 01:44 PM
relaxed00's Avatar
The red light on the dash comes on when I switch the key in the on position but while I'm cranking it goes off and stay off. It didn't blink at all.
Old Feb 15, 2012 | 01:20 AM
relaxed00's Avatar
Is there a relay or a fuse that would stop my car(2003 S-type V8) from firing? If so could someone please tell me where can I find it?
Old Feb 15, 2012 | 02:23 AM
JagV8's Avatar
They're all listed in the handbook as I recall
Old Feb 15, 2012 | 08:28 AM
Jon89's Avatar
Just to rule it out, check and re-set the inertia switch in the door jamb....
Old Feb 17, 2012 | 05:27 AM
relaxed00's Avatar
I rested the inertia switch (a lil FYI its located in the driverside kick panel not close to a fuse box). But still no spark and no new codes. I also pulled each spark plug out and put a little oil in each cylinder because it sounded like things were beginning to get dry. And I tried to move a few relays around and still nothing. All the fuses seem to be good as well.
Old Feb 17, 2012 | 05:59 AM
JagV8's Avatar
Don't mess with the throttle body.
What actual code # was it? (Not the words.)
Old Feb 17, 2012 | 01:08 PM
Bobco51's Avatar
If it is an immobilizer you could find an independent jag shop that has IDS or Autologic they both can reset modules, transponders ect
Old Feb 17, 2012 | 02:24 PM
relaxed00's Avatar
RL turn signal is out is the only code it has shown.
Old Feb 17, 2012 | 03:08 PM
Languid's Avatar
Weird one, but be careful not to overload the starter motor while tryting to start the car. The starter notors are designed for very short duty cycles, and it is very easy to overheat them & burn them out.
It does sound as though the anti-theft system is isolating the ignition system. Seek out Brutal (a member) on this Forum: he is one of your best bets.
Cheers,
Languid
Old Feb 17, 2012 | 03:21 PM
Have you had the car scanned for codes, or are you just going with the message center?
Old Feb 17, 2012 | 03:33 PM
JagV8's Avatar
What is the code please? You know, the one with digits (numbers) in it.
Dagny
Jun 11, 2024 01:06 PM
Quantico
Oct 13, 2015 10:34 PM
Charlene n John
Sep 28, 2015 06:01 AM
jagfool
Sep 14, 2015 07:50 PM
Charlene n John
Sep 6, 2015 11:03 AM
