2003 s type 3.0 Jaguar please help car wont go over 15 mph
Old May 9, 2014 | 05:08 AM
loftonfa's Avatar
Default 2003 s type 3.0 Jaguar please help car wont go over 15 mph
Just got it from the auction its been sitting for a while coolant was empty and oil was empty also car wont go over 15 mph had to get it towed home didnt want to damage my Jaguar anymore .....
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P1316
P1647
P1000
Smoke coming from both pipes Im assuming its the coolant or the oil any info is appreciated hoping I dont needa new tranny do I?
Old May 9, 2014 | 05:56 AM
police666's Avatar
oh dear, never seen so many misfire codes
P0300
P0301
P0302
P0303
P0304
P0305
P0306
P1316
all the above relate to misfires, 1st thing i'd do is check for oil/water contamination of the coils then replace them and the plugs along with the cam cover gaskets (if coils have water/oil on them) while your there.
P1647 relates to 02 sensor but id see how things are once misfire has gone.
whats wrong with the gearbox ?
a search would gotten you all the info you wanted instantly
i also suggest you download alldata and / or jtis from the link in my sig
Old May 9, 2014 | 10:50 AM
loftonfa's Avatar
So dont take it to a transmission shop first
Old May 9, 2014 | 11:14 AM
police666's Avatar
Going on those codes, no.
The is no way anyone can diagnose a gearbox fault correctly with engine faults.
What problems are you having with the gearbox.
Old May 9, 2014 | 11:15 AM
I wouldn't.
Welcome to the forum loftonfa, when you get a chance post an intro in the new members section.
Follow 666's advice and try and track down the misfires first, I'd be trying to check for engine damage before spending too much on it.
What are your plans if it has been overheated? Any rattles when it's running?
Old May 9, 2014 | 11:37 AM
JagV8's Avatar
Ignore trans until engine etc is 100%.
Old May 9, 2014 | 12:29 PM
loftonfa's Avatar
I replaced the battery because it was sitting so long. I am going to get new spark plugs and ignition coils replaced today and get the coolant leak fixed and a oil change. I appreciate all the help guys....ill post the outcome in a couple hours stay tuned.
Old May 12, 2014 | 01:53 PM
loftonfa's Avatar
Changed the battery car starts perfectly warning restricted performance and white smoke out the tail pipes and car still wont go over 20 mph engine coolant warning appears mechanic says blown headgasket and I need a transmission without even running diagnostics Ibout the car for 2300 should I get rid of it now or is it worth repairing and how mich should I pay for parts and labor if he is correct
Old May 12, 2014 | 02:41 PM
police666's Avatar
did you replace the coils and plugs ? codes ?
Old May 12, 2014 | 05:50 PM
Mikey's Avatar
The blown head gasket sounds plausible.
Why do you think it needs a new transmission?
Old May 12, 2014 | 05:57 PM
JagV8's Avatar
Stick to post #6 unless you've more than one guy's opinion.
Old May 12, 2014 | 06:16 PM
Didn't #4 & #5 have the same opinion?
Old May 13, 2014 | 01:38 AM
JagV8's Avatar
Yes, but seems ignored.
Old May 14, 2014 | 05:28 AM
EastFalk
Aug 29, 2015 08:22 PM
Aegis21
Aug 27, 2015 08:30 AM
kesslari
Aug 27, 2015 06:26 AM
Terrance Williams
Aug 26, 2015 11:50 AM
mkrion
Aug 26, 2015 11:43 AM
