2003 s type abs and dsc fault
Old Aug 5, 2012 | 11:28 AM
jgoode's Avatar
Default 2003 s type abs and dsc fault
coming home on turnpike drive over rumble strip at prescribed speed at the tool booth, abs and dsc lights immediateily came on and got abs fault and dsc not available in the dash display, cruise control was then disabled. after parking at home, and restarting, the dsc light went out but still have the abs fault. what can I do to clear it? havent tried it this morning yet, can I trust the
autozone or o'riley readers to celar it? or can they?
Old Aug 5, 2012 | 12:09 PM
Jon89's Avatar
A dying battery is always the first suspicion in these cases. How old is yours?
Old Aug 5, 2012 | 12:35 PM
JagV8's Avatar
Could be a bad connection, whether battery or ABS, or a genuine ABS problem - which could be rust on the sensor rings, a loose ABS sensor - or even a failing wheel bearing.
Anyone with a jag-specific tool could read the codes in the ABS module if you want to know what it detected. Its light will self-clear above some lowish speed (10mph?) if all is now OK.
Old Aug 5, 2012 | 01:44 PM
jgoode's Avatar
thanks, i'm hoping it was set off by the turnlike rumble strip in the pavment, guess will know
next time its driven....
Old Aug 5, 2012 | 06:49 PM
abonano's Avatar
+1 on JagV8's advice on getting the codes scanned. You will need a Jaguar specific code reader to get any abs/dsc related code(s) - A normal OBDII reader will not do the trick - good luck. When you get the code(s) research the forum - otherwise post them and we'll steer you in the right direction.
Old Aug 15, 2012 | 10:08 PM
jgoode's Avatar
Default faults are gone
The abs fault is no longer displaying in the dash, I am satisfied that the
speed bumps on the turnpike set it off, and it reset after driven the next morning......
Thanks for the replys
Old Aug 16, 2012 | 07:42 AM
abonano's Avatar
That's good for now... if you do get the abs/dsc fault coming back (probally will - don't take offense) post the codes - you could indeed have a loose connection or loose solder joint within the abs controller as pointed out above.
Hoping you never get the dreadded abs/dsc fault... just my $0.02
way2far
Aug 31, 2022 09:26 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
David Thompson
Sep 3, 2015 07:48 PM
pnwrs2000
Sep 3, 2015 11:55 AM
dcvickers
Sep 2, 2015 06:14 PM
