2003 S-Type jag
Old Mar 24, 2018 | 07:16 PM
smahoneyinc3's Avatar
Default 2003 S-Type jag
I just bought a 2003 s type jag. Owner said the engine was bad. My question is as folllows. If the key fob has a bad circuit board will that cause the car to not run and or the owner out a stereo in that was not factory will this cause the car not to run
Old Mar 25, 2018 | 06:36 AM
Welcome to the forum smahoneyinc3,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to S-Type forum. Members here with the same model will be able to help.
Old Mar 25, 2018 | 07:25 AM
Some more info will help, is it a 4.2 or a 3.0, are there any codes stored, what happens with the PATS light (the red light in the middle of the dash) when you turn the ignition on? Does anything else happen when you try and start the car?
Old Mar 25, 2018 | 10:07 AM
Default 2003 S Type Jag and 2000 S Type Jag
They both are 3.0 we pick the car hop Monday so will let you know by Wed if not before. Thank you
Old Mar 25, 2018 | 07:23 PM
JBzXJ40's Avatar
If the remote isn't working, it shouldn't affect the car from starting. Most of the time they are just corroded inside and you can try to clean them to see if they come back to life.
As for the non-start, could be many things.
+1 smahoneyinc3 - Is the PATS light on top of the dash blinking? does it even crank?
Any faults/warning messages on dash while trying to crank?
Old Mar 25, 2018 | 07:44 PM
Get the car tomorrow will keep you posted
Old Mar 26, 2018 | 08:55 PM
I'm have the car pulled the codes they are as follows
Po102
Po112
Po116
Po121
Po128
Po198
Po560
Po1108
Po1532
Po1549
C1165
Po1122
Po1000
Po1108
C1165
Old Mar 28, 2018 | 06:37 AM
JagV8's Avatar
Po -> P0 then look them up - see file(s) on JagRepair.com - Jaguar Repair Information Resource or better still get the free download workshop manual JTIS.
Rebecca Scott Bell
Mar 28, 2018 12:04 AM
Gary Bokelmann
37
Jun 4, 2017 10:13 AM
doorjok
Oct 4, 2016 10:27 AM
Aug 31, 2006 02:45 AM
Audio/Visual Electronics
Jul 29, 2005 07:22 PM
