2004 STR rotors
Old Dec 16, 2010 | 03:42 PM
uropnm6's Avatar
Default 2004 STR rotors
Hi! Has anybody tried these rotors for the 2004 S type R with the brembo brakes, I asked if they were the 365mm & 330mm and their response was that these will fit. So I was wondering if any one has ordered from this company. I was quoted $420 for the front & rear rotors drilled & slotted $34 to ship good price just wondering on the quality. Ebay #320621179133 sorry can't post a link
Thanks in advance Paul
Old Dec 16, 2010 | 04:42 PM
Riski's Avatar
Hmmmm seems right but I would be iffy about it.....let me know how that goes!
Old Dec 16, 2010 | 10:51 PM
vance580's Avatar
You'd be better off getting the brakeperformance.com cross-drilled and slotted. They are about the same price. I believe mine were 460 shipped. They are a company not an ebay seller and they are a perfect fit. I've been running the black coated ones for about 4 months now with no problems. I have bought ebay ones for another vehicle I used to have and the coating wore off in a few months and were already rusting where the pads werent hitting. After about a year they rusted from the inside out on the brake surface and the rotors were shot. So anything with brakes from ebay kinda has me leery. I'd rather buy from a website or store. The brakeperformance.com ones also have a lifetime warranty against defects so if they do what the ebay ones did they will be getting them back.
Old Dec 17, 2010 | 06:42 AM
uropnm6's Avatar
Thanks that is the best info to get, personal experience.
Old Dec 17, 2010 | 03:59 PM
Staatsof's Avatar
Do some searching on this topic as it has been covered so many times. There are several alternatives out there which are a whole lot cheaper than the OEM ones. Pads and rotors. The stock pads really stop the car well but they are so GD messy.
There's no need for cross drilled or slotted rotors on this car unless you're going to drive it on the track and then there are a whole lot of other issues to address.
I would stay away from the the cross drilled ones. You're just looking for problems. I have no idea what the dimpled ones are supposed to do except look like cross drilled but not crack.
If you just must have them to look cool then be aware of the potential issues regarding slotted and cross drilled rotors. There ARE benefits but there also ARE drawbacks. Do some research and not just on this website.
Bob S.
Old Dec 18, 2010 | 01:55 PM
fergs03R's Avatar
or you could go with the EBC GS series..total shipped for all four is $ 335 ish from here http://www.tognottisautoworld.com/pa...ource=googleps
Old Dec 18, 2010 | 02:01 PM
fergs03R's Avatar
And i would be careful to make totally sure they are the right size as 95% of online searches do not give you the brembo size which is 365MM(14.4 inch) front and 330MM(13 inch rear)..non vented
and I second the comment about brake performance as well...good stuff and they lowered the price of the fronts by 50% since I was quoted 6 months ago
Old Dec 18, 2010 | 04:32 PM
uropnm6's Avatar
I have tried to order these before. They can not get them , they say that they are in engineering and not yet available for sale? I have had no response from EBC.
Old Dec 19, 2010 | 09:15 AM
JagV8's Avatar
Apparently the rears really ARE 330mm even though the sales brochures (I have several!) say 300mm
Old Dec 20, 2010 | 09:20 AM
clubairth1's Avatar
Community Influencer
Several people have used Rock Auto with good luck. You want Centric brand rotors. Search by part number. These are the correct rotors for the STR with factory Brembo brakes. 2003-2005. Remember the 2006-2008 STR had smaller rotors and a much simpler non Brembo brake system.
Fronts-Centric #12020018 $100 each
Back-Centric #12020019 $70 each
Old Dec 20, 2010 | 11:33 AM
Mafioso's Avatar
Are there vented brembos for the rear?
Old Dec 21, 2010 | 09:02 AM
JagV8's Avatar
I don't think they'd fit (width-wise). Or if they were narrow enough then I think they'd be too weak maybe. Other jags with vented rear Brembos are 10-13mm wider to allow for the air gap etc.
Old Dec 21, 2010 | 09:34 AM
clubairth1's Avatar
The Centric brand are factory replacement so no the rear rotors are not vented on the STR with Brembo's.
Thanks JagV8 I did not think about the vented ones being wider. I wondered why they were not vented.
Old Dec 21, 2010 | 09:47 AM
JagV8's Avatar
I'm slightly puzzled as to why jag didn't use vented Brembo rears as they did on some other of their other R cars. ("Didn't need"?)
Old Dec 21, 2010 | 09:57 AM
Staatsof's Avatar
It might have had to do with the separate emergency brake setup and that not being able to work on such a wide rotor? Stuff gets done for strange reasons when the production run is small.
Bob S.
Old Dec 21, 2010 | 08:48 PM
vance580's Avatar
Centric is the brand that brakeperformance.com sells. If you get there factory replacements that is what you will get.
Spazzzzzzzzzy
XJ40 ( XJ81 )
Oct 5, 2015 04:05 PM
JaguarSV8
Oct 1, 2015 01:58 AM
millertic
Sep 30, 2015 08:11 PM
SoCalJagS
Sep 27, 2015 09:20 AM
