2005 2.7D DPF or no DPF?
Old Aug 12, 2020 | 05:50 PM
mrmike's Avatar
Default 2005 2.7D DPF or no DPF?
Still waiting for my A/C compressor to arrive, in the mean time I was thinking about an Oil change etc. I notice on the containers that apart from 5W40
there are also some added "Notes" like dpf etc. I was looking at the Castrol Magnatec and EDGE range. I read somewhere that not all 2.7Ds had DPFs fitted.
So how do you tell if you have a DPF fitted, is there a VIN after which all diesels had DPFs fitted? So which to choose?
Old Aug 13, 2020 | 04:52 AM
JagV8's Avatar
You'd be better asking on https://www.jaguarforum.com/forumdisplay.php?f=27
as there are few diesel owners on here.
Old Aug 13, 2020 | 01:20 PM
User 42324's Avatar
If it's a proper 2005 car you should be OK & not have one fitted. Check the exhausts at the rear & (assuming it has a standard exhaust) if they point down you don't have a DPF, if they point straight back, you do.
Old Aug 13, 2020 | 05:21 PM
mrmike's Avatar
It was registered in Spain in march 2005 so I guess produced a month or two before. The exhausts point down, Using the i930 I haven't noted anything about the DPF.
Good, I have never understood the logic of filling the motorways in the countryside with soot of any type.
I will get the non DPF oil
Old Aug 13, 2020 | 06:09 PM
User 42324's Avatar
The i930 will give you no info about a DPF, even if you had one fitted.
Old Aug 14, 2020 | 01:55 AM
mrmike's Avatar
Thanks everyone.
Old Aug 14, 2020 | 02:45 PM
JagV8's Avatar
The DPF attempts to prevent that by burning the soot into CO2. If you have non-DPF then you are indeed (to some extent) filling the ... with soot.
Old Aug 14, 2020 | 05:05 PM
mrmike's Avatar
I must admit I have never gone into what the DPF does, But is carbon (heavy like coal) worse than CO2?
Old Aug 15, 2020 | 05:00 AM
JagV8's Avatar
Yes to human health because it is tiny particles which get into lungs, cross the brain-blood barrier etc.
CO2 is bad in terms of global warming / climate change, of course.
tyler500
Aug 31, 2021 02:59 PM
JagV8
34
Jul 17, 2021 07:30 PM
mgbgtred74
Aug 3, 2019 03:35 AM
Partick the Cat
Diesel variants - All models
Mar 21, 2014 11:26 AM
ken@britishparts.com
Oct 25, 2008 03:31 AM
