2005 Jaguar s-type throttle motor 2 pin connector
Old Dec 14, 2025 | 08:04 PM
Kendsley's Avatar
Default 2005 Jaguar s-type throttle motor 2 pin connector
My two pin connector on the right side of the throttle
body connected to the throttle motor finally imploded in my hand when i tried to remove it. The wires are exposed. I can still connect them but I can't find a connector pig tail to replace it. I have also checked the Lincoln LS 3.0l website but can't find one. Any ideas on a after market replacement?
Old Dec 14, 2025 | 08:24 PM
Peter_of_Australia's Avatar
This seems to be a VERY common issue.
Very recently someone asked the same question - here it is incl. my response:
https://www.jaguarforums.com/forum/s...r-plug-293476/
Old Dec 14, 2025 | 09:17 PM
Kendsley's Avatar
Default I found this
Ford CU2Z-14S411-SA Wiring Harness Pigtail Connector WPT-1269 Factory Sealed
Old Dec 15, 2025 | 11:36 AM
clubairth1's Avatar
Community Influencer
Thanks so much for posting back with REAL information! You even included both the connector AND the wiring harness part numbers!
Good job! This should save people a bunch of time too.
Old Dec 15, 2025 | 11:22 PM
Good to see that you found the connector. I showed the best work-around, which you could do, if you don't know the P/N, or if you can't get the part.
But I like the idea of being able to buy a matching connector for the throttle motor, and I am ordering two of those on Aliexpress (AUD$ 26.83 incl. GST for 2 of those WPT-1269).
Old Dec 31, 2025 | 07:42 PM
Kendsley's Avatar
As a follow up...I was able to remove the wiring and clip. I used the original wiring with no issues.
Peter_of_Australia
Jun 25, 2025 09:27 PM
marz1129
Mar 21, 2025 03:50 PM
Deepstuff
Aug 26, 2024 11:17 AM
mhamilton
Jan 24, 2024 09:49 AM
Rkhlopin
Nov 11, 2014 08:37 PM
