2005 s type 4.2 v8
Old Aug 29, 2016 | 07:03 PM
spots123's Avatar
Default 2005 s type 4.2 v8
I am getting a rapid beep sound when I open the door. Stops in about 5 seconds. Reoccurs when the engine shut off and again stops in 5 seconds.
Second problem the button on the dash will not open the trunk, the key for opens the trunk and the manual open also works.
Any help for me would be appreciated.
Jerry Spots 123
Old Aug 30, 2016 | 01:52 AM
JagV8's Avatar
What does it do in each of these when you open the door:
1. with engine on
2. engine off but ignition II
3. engine off, ignition I
4. engine off, key in, ignition off
Old Aug 30, 2016 | 09:32 AM
Kewpie's Avatar
Check to see if the valet button in the glove box is pressed. If so, button on dash won't work.
Old Aug 30, 2016 | 11:36 AM
spots123's Avatar
in all cases no beeping sound when you open door.
1. with engine on
Jerry
Old Aug 30, 2016 | 11:40 AM
spots123's Avatar
what an idiot I am. Your reply solved the problem.
Thanks, Jerry
NCJagman
Feb 6, 2020 03:17 PM
Chad
Sep 12, 2016 10:19 PM
lancervi50
Aug 30, 2016 02:04 PM
Uncle Fishbits
Aug 16, 2016 10:39 AM
capt
Jul 12, 2016 05:58 PM
