2005 s type nightmare
Old Apr 5, 2010 | 11:08 AM
brian's Avatar
Default 2005 s type nightmare
Hello everyone - I was stuck in Atlanta traffic day before yesterday when my 2005 s type 3.0 went into fail safe mode. I moved off to the side of the road and performed several restarts and finally was able to make it another mile or so before back into fail safe mode. I drove several miles in fail safe mode with many angry drivers sharing their love on a Friday afternoon, but did make it home. When I read the codes I have a P2135 showing in memory. I believe this points me to the throttle body. Has anyone ever experienced this, and do I really need to replace the throttle body? It is a pricey little part. Any help would be appreciated. Thanks in advance
Old Apr 5, 2010 | 03:34 PM
JOsworth's Avatar
I hate to say it...But have you searched here on Throttle Body and Limp Mode?
Old Apr 5, 2010 | 07:51 PM
Bull27's Avatar
Was it raining?
Old Apr 6, 2010 | 07:41 AM
brian's Avatar
Default s type nightmare
Thanks for your responses - It was not raining it has been bone dry in Atlanta for the past week or so. I checked the connections for any corrosion or contamination and saw nothing out of the norm. I did find a pretty good deal on a used throttle unit, hopefully I did not waste my money. I will find out when it arrives tomorrow. Again thanks for your input.
Brian
Old Apr 6, 2010 | 08:02 AM
Bull27's Avatar
Brian
Hi Brian, the 2135 definately points to the throttle body, I believe 2135 is "throttle position sensor", which basically means your throttle bottle is F'd up or most likely it is throwing this code because of misdiagnosis i.e. water droplets screwing up the sensor.
So you are going to replace this yourself? If you do it would probably be really helpful to do a step by step walkthrough with pics.
Mine went into limp mode when it was not raining, however, it did rain a few days back, moisture might have just got been caught in there. Make sure that when you do replace the TB that you seal it up excessively. You never know if this new throttle body will have the same problem, and while it is out will be much easier to make sure that thing is absolutely water tight. Good luck
Old Apr 6, 2010 | 09:15 AM
JagV8's Avatar
IIRC a TB needs calibrating with dealer tool but good luck!
Old Apr 6, 2010 | 09:58 AM
Brutal's Avatar
Originally Posted by jagv8
iirc a tb needs calibrating with dealer tool but good luck!
???? Please show me in ids a programming for throttle body
its plug n play. The only thing you will sometines get is a higher than normal idle depending on how dirty your old throttle body was/is. The ecu will drive the iacs(idle air control) open to the learned position of the old tb. This will self learn again with time, or you can do a hard battery reset to reset the ecu to defaults and make it learn everything again......
Old Apr 6, 2010 | 10:40 AM
JagV8's Avatar
If it's a myth, great.
Old Apr 6, 2010 | 10:48 AM
Brutal's Avatar
Not that i know everything, i learn stuff here to you know, just ive seen and replaced many a tb in 13 years and never seen anything on reseting something with a special jaguar only tool....ids,wds...now back in the days of pdu if anyone was around then before the internet, you had to do a engine setup with pdu for 02 sensor replacement, kickdown, and target idle. Alot of stuff is dealer required, but i will pass along tidbits when able to help a diyer....thats just not 1. I would replace the tb and be done. The reason there are issues(codes) is because there are redundant system sensors like throttle position and pedal travel...if there is a disagreement in readings between them you will get retricted perf/engine failsafe....just think toyota
and it doesnt have to be duplicatable, in these areas it is better to error to the side of caution. When I get an extended warranty inspector that wants to clear the code annd drive to see if it returns...I just ask them to sign a release stating that theyre declining to replace a part that has shown to have a fault at 1 time....with Toyota's issues right now, that stops that merry go round real quick
Old Apr 6, 2010 | 11:28 AM
JagV8's Avatar
Yeah.... I never knew driving a Toyota could be so.... exciting
Old Apr 6, 2010 | 11:48 AM
brian's Avatar
Thanks everyone for your input's. I received the new/used throttle body today and got it installed. I took your advice and sealed the hell out of it. If moisture gets into this thing I don't deserve to drive anymore. I have only gone on a short test drive and i'm throwing no codes. It seems to have a little more pep on the take off, that might be my imagination because i've been driving my father-in-laws 4cyl pickup for the past couple of days. It is supposed to be close to 90 degrees here in atlanta today, i think that i will wait till it peaks and go out for another test drive. I have been experiencing another issue and don't know if they are related yet. When I am cruising below 40mph i will get an occasional loss of a couple of hundred rpms and a sound like i have a cylinder not detonating..a real hollow ping. It hasn't issued any misfire codes or anything yet...any ideas? Thanks again for all of your inputs.
Brian
Old Apr 6, 2010 | 01:23 PM
Bull27's Avatar
Brian
Good stuff, no idea on the loss of RPMS, other than torque converter, but from what you describe it doesnt sound like that.
What did you use to seal the throttle body? Did you get all the connections and "snap on" parts good?
Old Apr 6, 2010 | 02:33 PM
Brutal's Avatar
^^^^ YES MISFIRES, YOU CAN HAVE MISFIRES AND DEFINITLY NOT SET CODES. tHATS WHY WE HAVE A JAGUAR SCANNER THAT LETS US SEE MISFIRE COUNTS AND WHICH CYLINDERS. WITHOUT IT YOUR GONNA GUESS
Old May 10, 2010 | 02:06 PM
Brutal's Avatar
take off the air intake and see if there carbon buildup and if clean does the throttle blade seat fully or has it sat somewhere and gotten corrosion on the shaft causing it to stick alittle. If it is clean, and your old one was very dirty the ecu is opening the idle air bypass to what it did with your old 1, the new 1 doesnt need to be opened as far so you end up with a high idle. disconnect the battery after a hard reboot(touch both disconnected cables together to discharge the capacitors on the car) this resets ecu's to their factory defaults
way2far
Aug 31, 2022 09:26 AM
ZJag
26
Sep 5, 2016 03:33 PM
raffoulig
Sep 8, 2015 01:56 AM
KarimPA
Sep 3, 2015 07:32 PM
laserguy
Sep 3, 2015 02:02 PM
