2005 STR suggestions?
Look at what I just got yesterday... A BLACK ON BLACK 2005 S-TYPE R! Sounds better than any Mustang or Hellcat, for sure. Any common performance upgrades, besides the standard engine stuff like ARP head/connecting rod bolts, supercharger pully swap, injectors, and fuel pump?
First get all of the car working (Currently any problems?) and all the maintenance done. Has the transmission fluid been changed? Coolant? Brake fluid? Power Steering? What condition are the brakes in? The car has around 23-25 rubber coolant hoses and they are ALL beyond replacement at this time. Consider getting it done or one will fail then another and then another. SC oil changed? Rear diff oil changed? Suspension bushings and rubber boots will all be very worn at this point.
Now the biggest issue? Can you DIY any of this? That is really the key to owning a used Jaguar.
I had a 2005 STR and it was a great car and I had little to no problems BUT I did have to keep it up.
Same way, via OBD. You can run twin screws without remapping though with an aftermarket MAF (has a custom transfer function to prevent reaching the airflow limit), or standalone ecu if budget allows.
standalone would imply new tcm, new cluster, new immobiliser, new door module...
amgeater
Mar 14, 2014 08:35 PM
amgeater
Jul 19, 2013 12:11 AM
Tijoe
60
Oct 3, 2012 07:45 PM
