2005 STR suggestions?
Old Mar 14, 2025 | 07:41 AM
L4NDSH4RK's Avatar
Default 2005 STR suggestions?
Look at what I just got yesterday... A BLACK ON BLACK 2005 S-TYPE R! Sounds better than any Mustang or Hellcat, for sure. Any common performance upgrades, besides the standard engine stuff like ARP head/connecting rod bolts, supercharger pully swap, injectors, and fuel pump?
Old Mar 14, 2025 | 10:32 AM
Mecca148's Avatar
Nitrous or twin screw is the only way to go for huge power gains
Old Mar 14, 2025 | 12:46 PM
clubairth1's Avatar
Community Influencer
First get all of the car working (Currently any problems?) and all the maintenance done. Has the transmission fluid been changed? Coolant? Brake fluid? Power Steering? What condition are the brakes in? The car has around 23-25 rubber coolant hoses and they are ALL beyond replacement at this time. Consider getting it done or one will fail then another and then another. SC oil changed? Rear diff oil changed? Suspension bushings and rubber boots will all be very worn at this point.
Now the biggest issue? Can you DIY any of this? That is really the key to owning a used Jaguar.
I had a 2005 STR and it was a great car and I had little to no problems BUT I did have to keep it up.
Old Mar 14, 2025 | 03:07 PM
scottjh9's Avatar
exactly. I have an 06 str and love it. I have done everything myself except wheel alignment and tire changes. And that is because i do not have the equipment. If you self wrench that is super. If not. Have 6 to 8 grand ready for outside parts and labor
Old Mar 14, 2025 | 03:24 PM
JagSTR2004's Avatar
Best way to more power on these cars is a twin screw supercharger kit (over 600bhp).
Old Mar 17, 2025 | 02:44 PM
elDariusVargas's Avatar
and if its a prefacelift, how do you remap it?
Old Mar 18, 2025 | 03:43 AM
JagSTR2004's Avatar
​​​​​​Same way, via OBD. You can run twin screws without remapping though with an aftermarket MAF (has a custom transfer function to prevent reaching the airflow limit), or standalone ecu if budget allows.
Old Mar 18, 2025 | 12:30 PM
Sir, on the denso ecu? Have you done it?
standalone would imply new tcm, new cluster, new immobiliser, new door module...
Mithrilweaver
May 27, 2021 10:02 AM
amgeater
Mar 14, 2014 08:35 PM
amgeater
Jul 19, 2013 12:11 AM
Tijoe
60
Oct 3, 2012 07:45 PM
Spinall4
Jul 22, 2012 10:42 AM
