2007 front defroster not working
Old Nov 8, 2012 | 09:38 AM
Brett Higgins's Avatar
Default 2007 front defroster not working
Just bought this car:
2007 S-Type, 4.2 with Nav System.
Defroster was blowing air fine. Today (windshield was frosted) I cannot get air to blow on the windshield. All switches are functioning (lighting up) just nothing blowing on the windshield. Were should I start?
Thanks,
Brett
Old Nov 8, 2012 | 10:29 AM
JagV8's Avatar
Could be DCCV as it;s the commonest failure.
Old Nov 8, 2012 | 11:10 AM
tbird6's Avatar
If it's not blowing is the fan running? Do you get air out of any other vent?
I thought my defrosters were not working but I had no heat because of a heater core/AUX coolant pump problem.
Old Nov 8, 2012 | 11:19 AM
All other functions and vents seem to be working fine. Heated up fine. Fan sounds like it is working good just nothing going on the windshield
Old Nov 8, 2012 | 11:21 AM
Reading on - JaguarClimateControl.com my problem doesn't seem to be a "symptom" of the DCCV. All other vents were functioning. Just seems like the defrost vents weren't opening up
Old Nov 8, 2012 | 12:19 PM
tbird6's Avatar
You are right. It's not a DCCV problem. Any chance it's something simple like the defrosters are blocked somehow?
I think you need a dealer to cycle all the doors in the system to see if they respond correctly. I don't think you can do this with a standard scanner like the ELM327. Sounds like a dealer will be required.
It's a rare problem so please post back when you find the problem.
Old Nov 4, 2013 | 11:30 AM
Profesormsc's Avatar
Default windshield defrost problem
I have that same problem with my jag the defrost don't blow air on the windshield a mechanic advise to check the fuses #75#80and #99 under the driver side dash to desconnect the battery for 20 min to make a electrical reset,
but this was't the solution. for me
Old Nov 4, 2013 | 12:14 PM
police666's Avatar
Sounds like the stepper motors aren't functioning so no air directed to windscreen vents.
johnnie ryall
Oct 19, 2015 09:44 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
jrbong
Sep 3, 2015 12:54 PM
Javier Cepeda
Aug 29, 2015 12:50 PM
palian
Aug 27, 2015 10:24 PM
