3 lb. pulley install problems
Old Apr 14, 2012 | 12:29 AM
QuartzSTypeR's Avatar
Default 3 lb. pulley install problems
Any body else ever have the eurotoys pulley installer bolt snap in half with the pulley half way on? When trying to take the original pulley off the bolt head would just mushroom. Then the nut that was welded on the end broke the weld off. After I was able to get the tool back out I tried to use it again to install the pulley and the bolt snapped in half right at the stress nut. I was able to finally get the pulley on with other means, but I was just wondering if I'm the only one who has had this happen. I will get some pictures tomorrow.
Old Apr 14, 2012 | 12:06 PM
bfsgross's Avatar
Originally, I rented the Eurotoys puller along with 3 lb pulley, then chose to give the job to the mechanic. He cut off the stock pulley then chased on the new pulley with the bolt. Sorry it was such a farce for you to get it on. Now...does she have more stump pulling torque or what?
Old Apr 14, 2012 | 07:51 PM
I would've given it to my mechanic, but unfortunately that's myself as well . It was all worth it in the end, though . A couple of big smokey burnouts later and all the trouble was forgotten . The low and particularly mid-range power band is greatly improved. If I did it again, however, I would pull the whole supercharger out and send it out to get ported and let them do the pulley install at the same time.
Old Apr 15, 2012 | 08:07 AM
bfsgross's Avatar
LOL! Got to luv those burnouts. Ditto on the porting-pulley install. Did you order the air intake tube? Hi-flow cats and Magnaflow Tru-X center resonator/muffler? With these the throttle response, torque, and hp are amazing.
Old Apr 15, 2012 | 11:36 PM
A shop was supposedly building my intake tube, but they won't return my calls. They were going to do my exhaust work as well, but with the time and lack of communication from them, I am going to source another shop for that work. Is there a reason you are going back to the 2.25" piping? I was considering going to the 2.5" setup. The local drag strip opens up on the 25th, so I'm trying to get it done soon.
Old Apr 16, 2012 | 09:44 AM
qikcat's Avatar
I used the same make of puller they rent without issues. Could be the thing is really old or maybe your pulley shaft was slightly tighter then others? I just pulled the stocker off my spare blower and it comes off really easy with a blower not in the car!
Old Apr 16, 2012 | 08:22 PM
It was a total nightmare to yank off the pulley. Even after cutting it all the way through at one part, it still wouldn't budge until I cut more off. I used a micrometer to measure the shaft and new pulley, and the inside of the pulley was .77" and the shaft was .80" so it is definitely a squeeze to say the least. After talking it over with eurotoys, I think some of the blame is definitely on me as I think I misused the tool during the removal process. My question about the install tool though is this: Is the nut on the end of the bolt welded there, or is it just capped? I am used to regular pulley pullers and installers where the end nut is part of the bolt and is used to hold the bolt in place while the other bolt forces the install piece on.
Old Apr 17, 2012 | 03:47 PM
bfsgross's Avatar
Go with qwiketz's intake tube and maintain the stock 2.25" diameter pipes due to a drop off in torque with 2.5" pipe.
Old Apr 17, 2012 | 03:56 PM
jag79's Avatar
Great to see people sticking with the 2.25" piping as I have been maintainig since I stayed with the stock piping with the complete exhaust overhaul
Old Apr 17, 2012 | 10:27 PM
rasputin's Avatar
Where is the video?????????
Old Apr 18, 2012 | 04:07 AM
jag79's Avatar
Lolz video? I wish if I had time would do. If you do a search of my old threads I have pics up of the setup. That's the best I can do for now.
Cheers!!
Old Apr 18, 2012 | 02:58 PM
qikcat's Avatar
Mine is all one peice. There is a chance his has been mucked up a few times by other renters and who knows what it's got?
Old Apr 18, 2012 | 07:35 PM
Yeah, mine started out as one piece, I just wasn't 100% sure that the nut welded on the end wasn't just capped, or if it were a part of the bolt. I don't see how it would work if it wasn't part of the bolt, and it came off and left me in a bit of a bind. Eurotoys has been very helpful and has had great customer service so far.
Old Jul 12, 2012 | 08:46 AM
1320racer's Avatar
The puller I purchased failed due to a weld failure (see pics). I was sent a replacement UPS next day. Below are a some emails...
Mike,
Received! I appreciate your quick response to the weld failure!
The new welded nut and threaded rod worked perfectly. It took less than two minutes and I was able to press the small pulley on the rest of the way.
Sincerely,
Bryan
sales@eurotoysltd.com
Jun 20
to me
Hi Bryan,
I am glad that you finished it. I will re-write the tool instructions to be more specific, have been meaning to do that for awhile now. I contacted the tool maker and they said they have had 3 break in 10 years, and 2 has been in the last month. They changed who welded them, go figure.
Mike
Eurotoys Ltd.
847-464-4000
Attached Thumbnails 3 lb. pulley install problems-weldfailure1.jpg   3 lb. pulley install problems-weldfailure2.jpg
Old Jul 12, 2012 | 09:32 AM
clubairth1's Avatar
Community Influencer
Is this the puller you used??
Attached Thumbnails 3 lb. pulley install problems-super-charger-pulley-removal-tool.jpg
Old Jul 12, 2012 | 06:15 PM
Mike,
Sincerely,
Bryan
Jun 20
to me
Hi Bryan,
Mike
Eurotoys Ltd.
847-464-4000
That's the same way mine broke. Thanks for bumping the thread, I forgot to send my puller back and this reminded me.
Yep, that looks like the one.
afterburner1
Dec 16, 2015 12:12 AM
Dz1rfj
Sep 16, 2015 03:44 PM
pegasus3710
Sep 5, 2015 09:40 AM
mcdutch
Sep 4, 2015 03:38 AM
d a
Sep 3, 2015 02:34 AM
