4.0, No Heat
Old Nov 14, 2012 | 07:35 PM
Rex's Avatar
Rex
Default 4.0, No Heat
Everything worked perfectly until - I replaced stuck thermostat, flushed and bled cooling system. All is well except I have no heat??? Any ideas would be greatly appreciated. 2000 4.0 S-Type Sport.
Old Nov 14, 2012 | 07:45 PM
Air lock?
Was the heat good before?
Old Nov 14, 2012 | 07:51 PM
Rex's Avatar
Rex
Everything was perfect before. I though air lock too but nothing has worked so far. Even took it to independent and they could not get any air out either?
Old Nov 14, 2012 | 08:21 PM
The 4.0's have an auxilluary pump I think, that could be a problem too.
Old Nov 15, 2012 | 07:56 AM
abonano's Avatar
Did you purge the system of trapped air (As Norri pointed out - air lock) to the letter as outlined in JTIS?
Also, ensure you installed the thermostat with the ball safety valve (loss of words) pointed up at the 12 O'Clock position before proceeding. This is pointed out on JTIS as well.
Did you bleed the cooling system from the air bleed hose? Hose is located next to the master cylinder and opens up with a flat blade screwdriver.
Hope my $0.02 points you in the right direction.
Old Nov 15, 2012 | 11:10 AM
Rex's Avatar
Rex
We did all we could think of to bleed it. There is no bleed valve on mine (near the master ) so we took off the round plastic cap on the top of the thermostat housing. Due to the shape of the themostat and related housing, the thermostat will only go in one way so that cannot be it either. I am at a loss but it should not be a major item as it occurred with the system flush. When I changed the thermostat, priior to the flush I had the same issue but overcame it by manual compression of the hoses. Any ideas appreciated. The JTIS CD will not run on my computer.
Old Nov 15, 2012 | 12:21 PM
Rex's Avatar
Rex
Since I seem to be lacking the bleed screw, perhaps I need to pull the wipers and the plastic cover at the base of the windshield and remove the hose?
Old Nov 15, 2012 | 01:18 PM
Rex's Avatar
Rex
The problem must stem from something I did. Is it physically possible to put the thermostat in upside down without leaking?
Old Nov 15, 2012 | 04:09 PM
abonano's Avatar
Originally Posted by Rex
We did all we could think of to bleed it. There is no bleed valve on mine (near the master ).
It has to be there - I'll snap a pic of where mine is since we have the same model year/engine - that might help...
Old Nov 15, 2012 | 06:53 PM
Rex's Avatar
Rex
On closer inspection there is a hose coming from the back of the engine to the expansion tank. At the tank there is a strange fitting - white plastic - which may have a plastic screw recessed in it. Is this the critter?
Old Nov 15, 2012 | 07:02 PM
Rex's Avatar
Rex
Eureka!!! Black hose with screw fitting - tucked under the master cylinder and impossible to see or get at but I found it and with very long needle nose pliers pulled it up!!! Tomorrow I will have heat! Thank you all.
Old Nov 15, 2012 | 07:09 PM
Let us know if it works.
Old Nov 15, 2012 | 07:48 PM
abonano's Avatar
Good Deal!
Old Nov 15, 2012 | 09:06 PM
Rex's Avatar
Rex
Bleeding operation failed. Could someone tell me the correct procedure? My JTIS is not working.
Old Nov 15, 2012 | 09:15 PM
Try this
File Type: pdf
Old Nov 15, 2012 | 09:21 PM
Rex's Avatar
Rex
Thank you, will try again soon.
Old Nov 16, 2012 | 11:20 AM
larrymelton's Avatar
I had the same problem after I replaced the dccv and it ended up being the sensor plug on the bottom of the resouvar tank. After I snugged it up everything was fine.
Old Nov 18, 2012 | 08:44 PM
Rex's Avatar
Rex
Thanks to all, I am getting close but the bleed procedure says to idle until a steady stream from bleed valve, I have not yet got that. Will keep at it. Had heat for several minutes today but not "success" yet. Will repeat the entire proceedure until I get it. Great car, first time it has baffled me.
Old Nov 19, 2012 | 05:28 PM
Rex's Avatar
Rex
Tried again today - no luck. I suspect something else as when I open the bleed valve, there is not a steady stream but only a trickle. Any suggestions? Someone mentioned a sensor in the coolant tank - where? Is there a bleed for the auxilliary heat pump? Seems weird that all was fine until I replaced the thermostat (which I checked alignment today).
Old Nov 19, 2012 | 05:31 PM
Is the auxiliary pump running?
