4.2 Coolant Leak From Back of Motor..
Old Jul 10, 2010 | 07:26 AM
  #41
Staatsof's Avatar
Originally Posted by jagv8
I think it's the coolant hose back from the TB (throttle body). If so, only some models would need it i.e. those with the TB at the back of the engine. It's at the front on most, I think
There's probably a similar hose on each of the SC jags.
I'm up for a better hose if someone finds one. If I have to do this job on my car, I'd sure hate to have to do it more than once.
This is my understanding about which hose this is but is this the one or is it another?
https://www.jaguarforums.com/forum/s...35&postcount=7
Old Jul 10, 2010 | 07:47 AM
  #42
JagV8's Avatar
I too understand it's that one. Part AJ8 9746.
Known as hose-heater by the UK jag dealer but otherwise as Throttle Body Coolant Return Hose.
Old Jul 10, 2010 | 08:54 AM
  #43
Brutal's Avatar
theres no plastic on/in the hose assembly. Simply reffereing to plastic and rubber on todays cars that deteriorate with heat. This is a throttle body heater and we all(most of us) know what heat does to power production(goes down due to less dense air). I have BYPASSED the TB heater on my Nissan and for those not in the FREEZE belt of harse winters. I would consider deleting this hose entirely and plug off the port under the sc with a silicone hose cap. I would recommend this where you wont get icing of the TB. Or you can make a bypass where the hose is used, but you disconnect the 2 ends from the TB and connect them together. In the winter just reconnect to the TB
Last edited by Brutal; Jul 10, 2010 at 12:10 PM. Reason: miss spelled words and incorrect words changed the meaning I was trying to convey
Old Jul 10, 2010 | 11:17 AM
  #44
clubairth1's Avatar
Community Influencer
Staatsof;
I do understand what your saying but this repair has been quoted to several people on the forum to cost from $1200-$1800. The hose is $20. For that kind of money I WILL change this!!! After several guys do it and we get a good set of instructions I think it would be something to do anytime the car has 50K miles or more.
I also like the Silicone hose idea a lot. Don't know what it takes to get one made with that material?
Brutal again thanks for the extra tips. This is a really tough repair job!!
Old Jul 10, 2010 | 12:05 PM
  #45
JagV8's Avatar
At 50K miles? Eek, mine's at 75K already
Old Jul 11, 2010 | 10:47 PM
  #46
ttwotees's Avatar
I don't believe the coolant return hose has any plastic in it. It appears to be solid rubber and you can protect it with thermal sleeve material. As far as not wanting to
perform this repair personally, I guess that's an alternative, albeit an expensive one.
So far my repair has cost me about $200 for parts and about 6 hours of time.
Old Jul 12, 2010 | 04:46 AM
  #47
Staatsof's Avatar
Default Can we merge these threads????????????
The discussion is being spread across multiple threads and it's very fractured.
Regarding the hose. See the other thread. That fitting is made from something. It could be a heavy duty glass reinforced duty nylon which should be fine. I'd suggest a complete autopsy of the hose and a look at what else is around the failure point.
Strange.
Bob S.
Old Jul 12, 2010 | 10:40 AM
  #48
H20boy's Avatar
I can merge, but it will merge by date of posts..if that's ok, I'll do it.
After done, I can't undo it.
Old Jul 12, 2010 | 10:44 AM
  #49
JagV8's Avatar
Might be better to just close this one so the other carries on but this one stays as-is?
Old Jul 12, 2010 | 12:55 PM
  #50
Staatsof's Avatar
Might I suggest that we include a link to it then as both are very much related.
Bob S.
Old Jul 12, 2010 | 01:16 PM
  #51
H20boy's Avatar
Done (closed). If you need anything else related to this thread, admin-wise, please PM me.
Another thread directly (and sometimes cross referenced) -> the supercharger removal and hose repair thread
Old Jun 28, 2018 | 02:05 PM
  #52
Aamir Butt's Avatar
Originally Posted by ttwotees
I'm doing this repair also, but am not going to pull the engine. According to the JTIS, it can be done in the car and the instructions I downloaded looks like it will take time
but still not too difficult. I will be taking photos and passing along the instructions once I get them scanned.
Do you still have copy of those instructions. I have run into the same problem was reading through the Forum and would certainly appreciate the help
Old Jun 28, 2018 | 02:26 PM
  #53
JagV8's Avatar
8yr old thread!
JTIS is a free download or easily bought from the net so just get it
Old Jun 29, 2018 | 05:05 AM
  #54
Staatsof's Avatar
Originally Posted by JagV8
8yr old thread!
That's OK, following the trevails of an owner interspersed with input from a qualified tech is much better than that medieval torture device known as JTIS ​​​​.
He's unlikely to get an answer from the OP because if I remember correctly it was this repair plus the "while I'm at it" supercharger "upgrade" that ended up making him unload this car.
This PDF is much better http://www.jagrepair.com/images/Auto...M-Workshop.pdf
BrentGardner
29
Dec 16, 2024 12:13 AM
Russ Graber
Feb 23, 2019 11:59 AM
RaceDiagnostics
Dec 11, 2015 10:12 AM
tberg
Sep 7, 2015 07:32 AM
innzane
Aug 27, 2015 07:58 PM
