4l failsafe engine mode
Old Nov 18, 2013 | 02:42 PM
mike213735's Avatar
Default 4l failsafe engine mode
Hi all,
I've been having a bit of an issue with my engine management light coming on and now this has moved on.
Yesterday, the car went into engine failsafe mode with the Amber warning. Whilst it was like this, it drove like it had a misfire. After about 5 minutes, it cleared and went back to normal.
I did read somewhere that cleaning the throttle body can help this. Is that the case?
Mike
Old Nov 18, 2013 | 03:05 PM
police666's Avatar
Don't clean the throttle body, it will cause more problems.
Check for codes
Old Nov 18, 2013 | 03:10 PM
Gus's Avatar
Gus
+1 on the codes! When you get them post the codes.
Old Nov 18, 2013 | 03:16 PM
mike213735's Avatar
Thanks for the replies.
My reader struggles to read the codes sometimes.
However, when I go into fail safe mode, there are no codes and no EML.
I did once get the code for throttle body, I can't remember but I think it was 1584.
Mike
Old Nov 18, 2013 | 07:45 PM
Gus's Avatar
Gus
Install you code reader and drive the car if and when the Failsafe comes up see if the code reader captured the code. As for the P1584 the fault description is “Throttle actuation malfunction”. See if you can capture that or another code and post it.
Old Nov 19, 2013 | 09:11 AM
JagV8's Avatar
The pain and cost of having to replace a TB due to a foul up in cleaning (especially as it probably isn't the cause)... Find another OBD reader instead, if need be!
Old Nov 19, 2013 | 10:29 AM
mike213735's Avatar
I captured the codes today when the eml came on and amber failsafe mode.
Codes were P1584 and P1383.
Mike
Forcedair1
Sep 8, 2025 01:57 PM
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
scottatl
Sep 4, 2015 08:08 PM
OkieTim
Sep 2, 2015 12:48 PM
