About time to garage the s type r
Old Oct 16, 2013 | 03:52 PM
larrymelton's Avatar
Default About time to garage the s type r
Living in northern Indiana in the winter can become somewhat of a challenge sometimes. But the one thing I found out last winter is taking the Jag out on a snowy day is no better than being on a saucer sled. So when the weather gets bad it's time to fire up the Jeep.
Old Oct 16, 2013 | 07:03 PM
Does that mean we won't see much of you over the winter then Larry?
I'm guessing you'll be spending some time on the Jeep forum then.
Old Oct 17, 2013 | 08:44 AM
DougB's Avatar
Ah Larry - living in Ontario is about the same - but I don't want to be in a "saucer sled" on the highway, with some other nut driving around on useless tires. Almost time to get the moth ***** & dryer sheets to stuff around the Jag. But then we have something to look forward to all winter...
Old Oct 17, 2013 | 09:07 AM
TonyX's Avatar
Last winter was very mild in terms of snow in my area. So the consensus is to moth ball the SType until next spring? Has anyone driven SType year round in Michigan?
Old Oct 17, 2013 | 09:26 AM
Mikey's Avatar
I've been driving mine year round every year in all weather since I bought it. It's no better/worse than any other rear wheel drive car. Real snow tires (not the useless 'four season') are mandatory.
Old Oct 18, 2013 | 04:07 AM
JagV8's Avatar
If the 300HP 4.2 is OK then the 3.0 should be easier.
I just keep my STR off the road!
Old Oct 18, 2013 | 12:26 PM
TonyX's Avatar
Mikey,
Do you have your snow tires mounted on second set of rims or swap tires each season? And Blizzak considered acceptale snow tires?
Old Oct 18, 2013 | 01:00 PM
oberthecat's Avatar
Originally Posted by TonyX
Mikey,
Blizzaks are very good. I had a 2004 GTO that I put them on at that car was awesome in the winter. With traction control and abs it worked very well. I worry about the people in cars with no tread and 4x4 drivers that forget you have to stop as well as go.
Old Oct 18, 2013 | 04:24 PM
Mikey's Avatar
Mikey,
Mine are mounted on a set 16" Jag rims from a 2002 (I think). Found them on eBay, payed next to nothing. Plain black steel rims would work just as well.
Blizzaks are a great tire as ober says.
stanjag
Dec 29, 2024 08:26 PM
DrScientist
Dec 9, 2015 07:36 PM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
dpappyp
Aug 27, 2015 06:31 AM
