ABS and DSC OUT HELP
Old Feb 1, 2008 | 07:34 PM
FactoryJaguarTech's Avatar
Default RE: ABS and DSC OUT HELP
There is never a car that cannot be fixed.
Did the dealer give you any codes? Or no codes stored?
Old Feb 3, 2008 | 10:00 AM
Global close is programmable. Tell them it is in dealer options on ids. Maybe they can do it for free by experimenting on your Carib they think it cannot be done?
The abs system should not turn off unless you turn it off. Besides, the codes are for front sensors not rear.
I would look very carefully at the bolts on your fenders etc see if it looks as though they have been off. 9/10 s-types I have with that kind of problem have a pinched harness behind bumper from some sort of impact.
Also could be that your wheel speed sensors are caked in snow interuppting the signal. This is more likely.
Old Feb 3, 2008 | 02:07 PM
www.Autoenginuity.com seems to have the best aftermarket deal with Jaguar addon package.
The ABS sensors in your car comprise of a toothed tone ring integrated to the hub with a a/c voltage sensor clipped to the back side of it. The hub assembley is held in with 4 bolts and new one will come with harness and sensor. I wouldnt replace it just yet though. Make sure the tranmsit ring is not loose. You can hook up a meter on a/c volts and spin the wheel with it off the ground. Make sure also that all 4 tire sizes are the same. Are they factory size tires? ALl these can make a difference to the way it reads and cause light to come on.
Old Feb 3, 2008 | 03:47 PM
Dont let them bs you. Tell them to fix it or keep it. And I apologize, in the pm, I said transfer box, you donthave one of them.
Sounds like the diff. Have done many for noise.
radiatn
Jul 2, 2021 04:45 PM
kingdom worker
Nov 14, 2020 03:47 PM
goges
Oct 5, 2015 04:53 PM
millertic
Sep 30, 2015 08:11 PM
