ABS/DSC Problem NEED HELP!
Old Oct 12, 2023 | 03:33 PM
Mclovin22's Avatar
Default ABS/DSC Problem NEED HELP!
So yesterday as I was going to the bank “ironically enough” my Jaguar decided it was the prime time to throw some DSC & ABS fault lights on the dash. I verified the codes with a scanner and was able to check out the car today better as it was around night time when I got home last night.
Sure enough I back the car out of the garage this afternoon and this is sitting on the ground, which I assume must’ve been hanging on for dear life yesterday when it came off. I assume this is the root of my problem as to my knowledge the ABS/wheel speed sensor connects to this.
From what I’ve been told I’ll need a new Hub but I wanted to confirm the part that was broken first and then go about trying to find a replacement.
Any help/suggestions are much appreciated.
Part that was flopping around for dear life
Passenger side for comparison
ABS fault/DSC fault semi solved
Old Oct 12, 2023 | 08:11 PM
kr98664's Avatar
Yep, that looks like the inboard side of a wheel hub.
Take a look at RockAuto to see some options. Note some listings mention the length of the sensor lead, so you may want to check yours:
https://www.rockauto.com/en/catalog/...ing+&+hub,1636
Here's a good thread with details about replacing the hubs on an early model. Most of the pics evaporated, but still plenty of good info. Can't say for sure, but late models are probably similar:
https://www.jaguarforums.com/forum/s...ics-faq-39466/
Darrol2004
Apr 1, 2023 12:29 PM
andyzeg
Jul 27, 2018 04:33 AM
LeeH
Apr 30, 2017 05:29 PM
bharvey622
Aug 21, 2013 07:56 AM
jgoode
Aug 16, 2012 07:42 AM
