Air conditioning motor clutch not kicking in
Old Aug 21, 2011 | 01:08 PM
mrblockpaving's Avatar
Default Air conditioning motor clutch not kicking in
Hiya, I have a 1999 v6 3.0l auto s-type
The air con doesn't work,
I have checked fuses and the control panel seems ok.
The clutch isn't kicking in when A/C is turned on
but if I run a live wire direct to it it does kick in,
However even with this direct wire with the clutch activated I stil don't get cold air even when I left it running for a while.
Do I have 2 seperate problems?
Does the A/C fluid need filling up before the clutch will kick in,
I have also had a battery drain problem recently that I think I have sorted, don't know if this has anything to do with it.
Any help or advice will be greatly appreciated,
Thanks, Bill
Old Aug 21, 2011 | 02:20 PM
JagV8's Avatar
If you force it to run with too little fluid you'll ruin the compressor. Get it checked/filled.
Old Jun 17, 2016 | 09:29 PM
zephyrprime's Avatar
Yes. You need adequate refrigerant or else the clutch won't engage. There is a pressure sensor on the low side that checks to prevent you from engaging the compressor without fluid in the system. This is a safety feature to prevent from killing the compressor by running it dry.
Kevin Burnaby
Jun 28, 2020 08:04 AM
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
Saturbo
Sep 8, 2015 07:35 PM
1100me
Sep 7, 2015 06:26 AM
XJsc-guy
Sep 2, 2015 11:43 AM
