Alarm issues
Old Jul 18, 2022 | 12:18 PM
XkBob's Avatar
Default Alarm issues
Hi am having a problem my S type 3L v6 works fine with fob entry and closes ok but if left locked for any length of time the fob won’t respond
I have to manually open the door the alarm sounds then the fob will respond ok
I have changed batteries in both fobs and also the car battery I’m baffled can anyone help please
Old Jul 18, 2022 | 01:13 PM
motorcarman's Avatar
MAKE, MODEL, YEAR?
Lots of MY changes to X200/X202 cars over the years.
TSBs are VIN specific.
Old Jul 18, 2022 | 04:04 PM
XkBob's Avatar
Default Alarm issue
The car is an S type year 2000 manual 3L V6 petrol
Old Jul 18, 2022 | 09:07 PM
Jaguar issued a few TSBs for the X202 (MY2002.5) but I don't see anything for the early cars about unresponsive transmitter signal.
Old Jul 19, 2022 | 02:15 AM
JagV8's Avatar
How long are you leaving it?
I know the later cars shut off the car's receiver to save power but it's after 7 or 14 days or some such.
Old Jul 19, 2022 | 06:27 AM
XkBob's Avatar
I’m only leaving it a few hours
Old Jul 20, 2022 | 03:03 PM
Lotibob's Avatar
Default Alarm....S type
For what it's worth, my '05 S type R suffered from similar alarm issues. Fob worked fine but after approximately 15-20 minutes, if you tried to open the locked door you had to use the key and the alarm went off. Gave up and disconnected horn....at least not so embarrassing. New batteries and later fob not the answer. Researched driver's door module failure issues via the forum....a common issue on S types. Purchasing a used...same year, same model etc. module not the answer. Removed module and discovered several pins on the module's multi-pin wiring loom connector were badly corroded...one even broken off! A little delicate soldering repair and the entire system worked like new after apparently being on the fritz for some time according to previous owner. Might be worth checking.
Bob G
Old Jul 20, 2022 | 03:53 PM
XkBob's Avatar
That sounds like a good possibility as it’s a 2001 car so I’ll give it a go and get back to you
thanks for the help
Old Jul 24, 2022 | 02:56 AM
XkBob's Avatar
Sorted fuse F7 that feeds the passenger mirror was blown replaced it and now all ok 👍
Old Jul 24, 2022 | 03:40 PM
Sportston's Avatar
Glad you got to the bottom of the problem. And what a cheap fix!
Old Jul 24, 2022 | 04:12 PM
kr98664's Avatar
Great find! Who'd have thought this would cause an alarm problem?
Anything special prompt you to check this particular fuse? Or were you just checking them all one by one?
Old Jul 24, 2022 | 04:35 PM
XkBob's Avatar
I just checked that fuse because both mirrors didn’t operate and F7 is marked up as passenger mirror so as the drivers mirror is fed through the door module when that worked aswell as passenger mirror I thought it could be linked somehow and it was
Old Jul 24, 2022 | 05:03 PM
Sportston's Avatar
I guess we can learn from this. Whenever we have an electrical problem, check all the fuses first.
5tevie
Sep 5, 2024 09:16 AM
Jagcrew
Sep 29, 2021 01:48 PM
jpeterson1973
Nov 4, 2013 12:47 AM
jpskiller
XJ40 ( XJ81 )
Jun 9, 2009 10:22 PM
Audio/Visual Electronics
Dec 16, 2005 03:34 PM
