Auto Headlamps stopped working
Old Jun 30, 2011 | 07:12 PM
Phlossn's Avatar
Default Auto Headlamps stopped working
Any advice on this subject is welcome. My autolamps stopped working, i must turn lights off/on manually. Lights will not turn off in daylight.
Old Jun 30, 2011 | 07:24 PM
Vampyre's Avatar
possible relay?
Old Jun 30, 2011 | 09:08 PM
phd12volt's Avatar
its the sensor. mine is out too.
it started working again for a day or too, now it is back to on all the time. i just leave it on AUTO anyway
Old Jul 1, 2011 | 09:08 AM
bfsgross's Avatar
My 03 STR has the same issue. Last week a Jag/Land Rover tech inspected her and I learned that the auto headlight sensor is in the mirror facing the road. The sensor on the dash is for the alarm beacon and daylight sensor for the a/c system. I'm going to clean sensor in the mirror with isopropyl alcohol and see what's up. If not the issue may be a relay or faulty mirror sensor?
Old Jul 1, 2011 | 09:32 AM
JagV8's Avatar
Caution: I think the sensors in the mirror are for (a) auto-dimming the mirror and (b) rain-sensing (if fitted).
I think the one in the dash is as you say AND for the auto-on lamps.
Old Jul 1, 2011 | 09:56 AM
bfsgross's Avatar
jagv8, I thought the same. The Jag/Land Rover tech is the regional troubleshooter (drives from dealer to dealer helping to solve difficult diagnostic cases). He pointed out that the sensor on the mirror facing the rear of the car is for auto dimming the mirror (cars headlights shining on the mirror from the rear), the sensor on the mirror facing the road is for the auto-headlights, the sensor on the dash is for alarm beacon and daylight sensor for the a/c. Who knows?
Old Jul 1, 2011 | 10:10 AM
phd12volt's Avatar
sunload sensor is in the dash according to JTIS........ SUNLOAD SENSOR 82.20.70
DUAL SOLAR SENSOR 6 pin black connector INSTRUMENT PANEL GLARE SHIELD, FRONT CENTER
JTIS wiring document FIG 08.1...location and wiring connector. Does both the auto headlamps and solar a/c
Old Jul 1, 2011 | 05:14 PM
bfsgross's Avatar
Then perhaps the dash sensor is the auto headlight sensor too? The other day the autoheadlights worked...not today though.
Old Jul 1, 2011 | 05:56 PM
JagV8's Avatar
Er... I think that's what "both" means..............
Old Jul 2, 2011 | 09:43 AM
bfsgross's Avatar
LOL jagv8. I meant "if" the auto headlight sensor is not in the mirror....
Old Jul 2, 2011 | 10:39 AM
On my 2003 the sensor is on the dash, how do I know?
I was driving to LA in bright sunlight, and noticed that the lights were on, swore to myself and wondered what could be wrong then noticed that the wife had flung a magazine on the dash covering the dome, I pulled it off and voila! problem solved.
Old Jul 2, 2011 | 11:28 AM
JagV8's Avatar
hehe, I wondered if you'd notice that
Old Jul 4, 2011 | 09:32 AM
bfsgross's Avatar
LOL, Leave it up to me to not notice. So it's final? The auto headlight sensor is on the dash. Is it or the relay that is toast?
Old Jul 4, 2011 | 02:30 PM
JagV8's Avatar
sensor, wiring, connector, relay (is there one?)... you'd have to test unless you have jag-specific diagnostics (which can read the sensor at least)
Old Jul 4, 2011 | 02:57 PM
JagV8's Avatar
Someone did, quite recently. Search should get you it but I think it's pretty easy - and likely in JTIS.
Old Jul 5, 2011 | 08:04 AM
Phlossn's Avatar
My lIghts stopped working and then started working again. And of course stopped again. Is the sensor difficult to change? It appears itmay be a challenge, since it is in the dash. Anyone know the approx cost of sensor and/or relay? Trying to establish budget for repair(s).
Old Jul 5, 2011 | 09:11 AM
phd12volt's Avatar
dash panel should just pop up. Want me to JTIS the removal sequence for you?
Old Jul 6, 2011 | 10:15 AM
Phlossn's Avatar
Absolutely, if it is not too much trouble. Thanks in advance.
Old Jul 6, 2011 | 12:13 PM
phd12volt's Avatar
go to pdf i posted 2 posts past this one (edited)
