Automatic headlights acting up....
Old Oct 27, 2010 | 03:55 PM
jag79's Avatar
Default Automatic headlights acting up....
Anyone know where the Automatic Sensor is located on the 03' S type R or S for automatic headlights turning on & off? For some reason mine are acting up alittle bit(example, not turning off when its daylight; takes awhile then turns off automatically), not sure if the sensor is dirty or what, any thoughts?
Thanks?
Old Oct 27, 2010 | 04:07 PM
JagV8's Avatar
I think it's a sensor in the same housing as the alarm (PATS) light (front centre top of dash by the windshield). Cover it fully to check.
Old Oct 27, 2010 | 04:14 PM
jag79's Avatar
Aaahhhhh....I see, thank you for the quick response, will test it out by covering it and un covering to see if its working properly.
Old Oct 27, 2010 | 04:15 PM
vance580's Avatar
If its not there check where the rear view mirror is on the outside of the windshield. There is a sensor on the backside that you can see if you look at the center of the outside of the windshield. May be really dirty or if you put a sticker or something in the center you may of covered it up.
Old Oct 27, 2010 | 05:50 PM
jag79's Avatar
Thanks amigo, but the sensor is up front of the center area of the dash. Tested it and it works fine, kinda strange why there was a delay in going off, ohh well, its all good.
sedonajag
Oct 8, 2015 07:38 PM
Johnken
Oct 2, 2015 10:12 AM
Markus
Sep 28, 2015 01:55 PM
kevinl
Sep 24, 2015 08:25 PM
