Back Seat A/C Vents
Old Oct 28, 2008 | 10:38 AM
TXCraig's Avatar
Default Back Seat A/C Vents
I noticed on my car even with the A/C at full blast, no air comes out of the back seat air vents located in the back of the center armrest. Is this normal? If there a setting to turn on to make them work? The car is still under warranty and I want it fixed if its broken. Not sure if they are there for looks for not.
Thanks.
Old Oct 28, 2008 | 11:29 AM
badmojo's Avatar
Default RE: Back Seat A/C Vents
I'm pretty sure that mine has a wheel next to the vents to shutoff the air flow. Be sure that this is to the open position. Also I don't believe that the air to the back is very strong.
Old Oct 28, 2008 | 12:35 PM
KAZsam's Avatar
Mine just trickles out it does not blow much.
Old Oct 28, 2008 | 03:05 PM
harounq21's Avatar
i think mine stopped working a while back
Old Oct 28, 2008 | 04:04 PM
ken@britishparts.com's Avatar
You may ask them to pull the center console tray out and make sure the ducts are still connected.
Old Oct 28, 2008 | 05:53 PM
harounq21's Avatar
how do you do that?
Old Oct 29, 2008 | 12:00 AM
DeathWind's Avatar
Check the mode switch for the A/C. If you are using the Auto feature, the vents are preset for thefeet and defrost vents. If you cycle through the mode switch until thedash vents are the only thing selected the rear vents are stonger. Well, at least on my '05 this is what I've found.
Old Oct 29, 2008 | 08:45 AM
harounq21's Avatar
did not help in my case. Sorry deathwind.
Maybe I will get around to opening it up myself.
Old Oct 29, 2008 | 10:44 AM
Uptown Girl's Avatar
ORIGINAL: badmojo
Badmojo is right. The air flow isn't that strong- I have noticed the same thing on mine and I too had the wheel positioned so the vent was open but not a whole lot came out.
Jeh
XJ40 ( XJ81 )
Oct 13, 2015 09:23 PM
jehart49
Sep 12, 2015 05:36 PM
tberg
Sep 7, 2015 07:32 AM
user 652867429824
Sep 5, 2015 12:53 PM
Dallas XK8
Sep 3, 2015 12:17 PM
