best spark plugs for 4.0?
Old Sep 3, 2010 | 10:51 AM
shaguarxk's Avatar
Default best spark plugs for 4.0?
Hi all,
I tried a search for this , no results.
I'm replacing all 8 coils on my 2001 4.0 with 70k miles so I want to replace the plugs at the same time.
My Toronto Jag dealer wants $23 ea for Iridium which is more than I want to spend. The local parts store wants $21 for NGK Laser PFR5G-13E (part #2761)which is what the NGK site recommends.
I talked to my indy tech who said not to buy Bosch platinums and he recommended getting plugs which were properly gapped (.050) right out of the box. Has anyone had any luck with other plugs for this car?
I'm looking for a platinum plug or better with an .050 gap at a cheaper price.
Please reply with part number if you can help.
Cheers.
GM.
Old Sep 3, 2010 | 10:56 AM
JagV8's Avatar
You might try the forum sponsors - at least they'll sell you the right parts
Mention you found them here as I think you get a discount.
Old Sep 3, 2010 | 12:06 PM
Mikey's Avatar
The OEM plugs lasted you 70,000 miles so there's no doubt that they are reliable and durable. There's no credible data (that I've seen) indicating that other brands are better or worse. Why be the guinea pig to find out that maybe some are worse?
Determine the correct OEM part number and do a search on the internet to find who has the best price and delivery cost.
Old Sep 3, 2010 | 12:12 PM
JagV8's Avatar
Try Amazon, too. There are some surprising bargains on there.
Old Sep 3, 2010 | 03:38 PM
MidlifeXJR's Avatar
You can try Rockauto.com. I just put NGK iridium plugs in the 4.0 S/C engine. I went with the iridium, as I wanted the longevity they offer. From everything I have read, they aren't going to do anything for performance, but the factory platinum's didn't wear very well.
It appears they would run about $7.50 each.
Old Sep 13, 2010 | 01:44 PM
cbgbglavan's Avatar
Default spark pug nonfouler
my car has no acceleration so i went to change plugs and found oil on the threaded part.
thought i would try nonfoulers to lift plug out a little.
stupidly I attached the nonfouler to the plug and installed it.
did not solve the problem. car actually threw misfire code, which it did not berfore. Now I have a new problem. when removing the plug the nonfouler stayed in and the 11/16 socket i need to remove it with does not fit into spark plug tube!
Does any one have any ideas how to get it out? Does the the tube come out?
Old Sep 13, 2010 | 02:06 PM
Mafioso's Avatar
non-fouler?
Old Sep 13, 2010 | 02:58 PM
itspec60's Avatar
I put in the plugs that the Jag manual calls for. They went 80000 with no problems. so I figured I'd put the same ones back in. I got a good price at sparkplugs.com.
Old Sep 13, 2010 | 05:09 PM
Gus's Avatar
Gus
I installed the Bosch platinum 4’s (4501) and they ran great then and runs great now. And yes you can get great deals on Amazon.com if you are not in a rush.
Old Sep 13, 2010 | 05:31 PM
shaguarxk's Avatar
Thanks for the input, guys.
I ended up buying NGK Iridium from the dealer here in Toronto.
They were installed today with new coils that I bought on ebay. Engine is now running perfectly with no more low rpm hesitation when going up hills or rough idling. I wish I had done this a long time ago.
Cheers,
Gerry.
Old Sep 13, 2010 | 06:46 PM
Mafioso's Avatar
Im still curious to know what non-foulers are.
Old Sep 14, 2010 | 08:32 AM
cbgbglavan's Avatar
if your plug is fouling supposedly you insert this into the plug port and then the plug into nonfouler. Temporary fix till you can figure out what is fouling the plugs. Did not work for me.
people also use them on their o2 sensors, somehow helps them pass emissions test.
By the way i was able to get the nonfouler out after taking off valve cover and wedging a chisel in so I could unscrew.
Old Sep 14, 2010 | 09:03 AM
Adrianl's Avatar
at risk of seaming like a plug, I bought most of my parts from these guys. They really are the best in my opinion
Old Sep 14, 2010 | 09:15 AM
Mafioso's Avatar
Its not anything like this is it?
http://kalecoauto.com/index.php?main...&products_id=5
Old Mar 6, 2011 | 09:45 PM
DavidRey's Avatar
What is the best size to gap the plugs? JTIS says .51 in to.57 in?
Old Mar 6, 2011 | 10:14 PM
aholbro1's Avatar
Put Bosch Platinum IR Fusions in my daughter's 3.0L 1500 miles ago, no problems. 85,500 total now.
Rock auto, $5.70 ea then $2 ea rebate through June, 2011.
cissdm
May 3, 2016 06:02 AM
BathoryFan
Sep 15, 2015 05:04 PM
Boeingtravel95
Sep 14, 2015 05:01 PM
Pristine97XK8Convertible
Sep 10, 2015 09:24 AM
Bowman
Sep 3, 2015 03:17 PM
