Which are better plugs Champion Iridium or NGK Iridium for STR??
Old Aug 9, 2010 | 05:40 PM
jag79's Avatar
Default Which are better plugs Champion Iridium or NGK Iridium for STR??
HEy guys I need your opinion on this which are better spark plugs for the STR Champion Iridium or NGK Iridium? The champions have a gap of .050 and the NGK's have gap of .040. What is the OEM spark plug gap for the STR Jag? On http://sparkplugs.com/results_app.asp?aaia=1410635 it says that the Champions are of OE for the STR, but I'm still deciding which one to choose, any help
Old Aug 9, 2010 | 05:58 PM
JagV8's Avatar
Denso iridium.
Old Aug 9, 2010 | 06:37 PM
ChrisSTR's Avatar
A spark plug is a spark plug. Don't sweat the small stuff.
Old Aug 9, 2010 | 06:49 PM
Mikey's Avatar
Absolutely agree, A plug is a plug, and a spark is a spark.
Old Aug 9, 2010 | 07:15 PM
jag79's Avatar
LOlz....yeah but there is a difference btw Iridium and Platnum head plugs. So all I wanted to know is which is better suited for the STR's, Champions or NGK, Denso is good too, but for the price of Denso I might as well get the OEMs.
Old Aug 9, 2010 | 08:05 PM
Mikey's Avatar
In price and durability, maybe. Performance, nope.
Old Aug 10, 2010 | 01:42 AM
JagV8's Avatar
Not true for modern engines.
Old Aug 10, 2010 | 08:56 AM
Mikey's Avatar
Proof please, and not marketing cr*p. Thanks.
Old Aug 10, 2010 | 09:08 AM
H20boy's Avatar
The original plugs in my XK8 were NGK iridium, so I replaced with similar. I know, not an s-type or an 'R', but still.
Old Aug 10, 2010 | 09:21 AM
JagV8's Avatar
Proof please, and not markleting cr*p. Thanks.
Read automotive research journals. Consider them marketing if you wish. Your car: you fit what you like.
The idea that a spark is a spark is .... somewhat behind the technological reality.
Old Aug 10, 2010 | 09:24 AM
Mikey's Avatar
I have, lots of them. There is no mention of 'improved performance'.
Link please.
Old Aug 10, 2010 | 09:29 AM
joycesjag's Avatar
taken from a simple google search:
Kenny Duttweiler of Duttweiler Performance in Saticoy, California is no stranger to making horsepower, especially with turbochargers. After years of building little turbocharged V-6 Buicks that produce in excess of 1,500-hp, he found a lucrative market in NMCA's "World Fastest Street Car" classes building 1,700-hp small-block Chevy V-8s for winning racers such as Bob Rieger and Rod Saboury.
Kenny had no idea that the solution to this perplexing problem would be a new iridium spark plug technology from Denso. In Denso's research for an OEM spark plug that would provide 200,000 miles of service life and lower vehicle emissions, Denso developed a new iridium alloy electrode spark plug. The progression from nickel alloy plugs to platinum plugs in 1982 was a giant leap forward in technology. Denso's introduction of the iridium alloy spark plug will prove to be even more significant, especially for high-performance and race engines. The major difference in the Denso Iridium Power spark plug and conventional platinum plugs, besides the alloy, is the size of the center electrode. A typical platinum plug has a 1.1mm diameter center electrode. The Denso Iridium Power OEM plugs have a .7mm diameter center electrode and the Denso high-performance plugs have a .4mm center electrode.
Old Aug 10, 2010 | 11:18 AM
Mikey's Avatar
Yes, I've seen that one and almost lost my coffee on the screen when I first read it.
http://corp.advanceautoparts.com/eng...20010101ds.asp
"When the word gets out about the new Denso Iridium Power spark plugs that added 750-hp to Kenny Duttweiler's 450-cid twin-turbocharged Ford, engine builders and tuners will gain more respect for the lowly spark plug."
This infers that the previous plug was unable to 'light the fire' causing a performance LOSS. If a given plug reliably fires the combustion chamber charge, there is nothing more to be gained by zoomy-swish expenseomatic plugs. The stock plugs do an excellent job of performing that function.
Here's another quote from the article:
"In Denso's research for an OEM spark plug that would provide 200,000 miles of service life and lower vehicle emissions, Denso developed a new iridium alloy electrode spark plug."
There's the durability I mentioned. Lower emissions? How? It must presume that the previous plug has failed and that the iridium plug keeps on trucking.
BTW- my professional background is 31 years in the engine development, manufacturing, field support and safety/reliability tracking business. I had years of direct OEM experience with better, faster, stonger plugs being peddled by the manufacturers. No difference in performance from best to worse, but a measurable difference in durability and reliability.
Old Aug 10, 2010 | 12:11 PM
JagV8's Avatar
Great. Where did I talk about "improved performance"? Oh yeah, I didn't. Don't accuse me of stuff I didn't do, please.
Old Aug 10, 2010 | 03:22 PM
Mikey's Avatar
So we agree then. Great!
Old Aug 10, 2010 | 05:43 PM
JagV8's Avatar
It doesn't look like you agree with me.
Old Aug 10, 2010 | 06:33 PM
jag79's Avatar
Sooo denso Spark plugs it is for my 03' STR!
Old Aug 10, 2010 | 08:08 PM
Mikey's Avatar
What specifically do we NOT agree on?
Durability- better
Price- higher
Performance- same
Old Aug 11, 2010 | 01:33 AM
JagV8's Avatar
You keep putting words in my mouth. We will never agree as long as you do that.
Old Aug 11, 2010 | 03:23 AM
Cadillac's Avatar
Each one has their opinion ,I think this thread will be look like "WHAT'S THE BEST OIL FOR S TYPE" .
You may agree or disagree that doesn't matter that much but what matters is keep your temper and good manner
