A/c blows hot air 2003 jaguar s-type
Old Jul 5, 2011 | 05:20 AM
Jagboy03's Avatar
Default A/c blows hot air 2003 jaguar s-type
I got a 2003 Jaguar S-Type, The DCCV had a leak, so i replaced it with a new one. To my surprise the reservoir tank began to leak coolant, which landed on the DCCV connector, suddenly cold air stopped and began to blow hot air. I checked freon, ok, checked compressor, ok, replaced with new DCCV, problem still exists i am desperately seeking help to troubleshoot the problem, please help
Old Jul 5, 2011 | 10:53 AM
You will find loads of DCCV info if you search. It is quite common to fry the CCM when the valve goes bad, so that may be worth a look.
Old Jul 6, 2011 | 07:51 PM
Jagboy03's Avatar
thanks, i will research the issue, hopefully i can find a solution fast, its hell in california lol.
Old Jul 6, 2011 | 08:04 PM
Michael Star's Avatar
Does your car have Nav?
Old Jul 8, 2011 | 08:29 AM
Jagboy03's Avatar
no it doesn't have nav, i keep reading on other threads that there is a possibility my climate control module fryed. i connected the old heater valve and only one solenoid closes, the other is stuck, compressor works, there is freon in the system, fuses ok, new heater valve and still blows hot air. im new to this forum and don't know how to navigate around for the right info regarding this a/c issue. i wonder if barnes n noble sells jaguar forum for dummies lol.
Old Jul 8, 2011 | 11:18 AM
You could try clamping the hoses from the DCCV closed to stop flow to the heater core, if that gives you cold air head for the CCM.
Take a gander at this thread https://www.jaguarforums.com/forum/s...-2003-a-36719/
Old Jul 11, 2011 | 04:00 PM
Jagboy03's Avatar
after massive research, my conclusion is that the CCM is damaged, so i headed out to a TV repair shop and was told that the circuit board was burned, cost of repair $45 bucks, crossing fingers :-). I will post the outcome, thanks for the help guys..
Old Jul 11, 2011 | 07:40 PM
Jagboy03's Avatar
installed the repaired CCM still blowing warm air not as hot as before. There is a wheezing noise coming from under the dash, anybody know what it can be? im ready for a new car and all though i love my car, i dont think its gonna be a jag!!!!
Old Feb 16, 2013 | 11:57 AM
Platinumforme's Avatar
Default A/C problem
Hi there, u know I had the exact same problem...I found here and on u-tube how to fix the damaged circuit on the Climate control w/a soldering pen from radio shack....it worked great. But now that I need the heater, the driver side is only Luke warm, compared to the passenger side...so another project to resolve... Best wishes to you. Linda
Old Feb 16, 2013 | 12:14 PM
Default U-tube link
Hi JagBoy, here's a link to view the disassembly of the CCM; the damaged circuit is pretty obvious to the eye. We've had to repair the circuit a couple of times w/ a soldering pen bcuz of coolant hose leaks. There is an upgrade to the CCM so it doesn't fry again, but I haven't done that as yet. Here it is for what it's worth
Sent from my iPad
Rupesh
Mar 25, 2016 03:33 PM
neruda
Sep 3, 2015 07:45 PM
big d
Sep 3, 2015 07:37 PM
Terrance Williams
Aug 26, 2015 11:50 AM
NinoGrimace
Aug 26, 2015 05:15 AM
