A/C zone problem !?
Old Aug 9, 2010 | 07:16 AM
Brutal's Avatar
you more than likely have a heater control valve leaking hot coolant into the passenger side heater core. The rubber plunger seal inside do fail, and the reason I say leaking, is cause if they were stuck open it wouldnt be luke warm. But HOT, there no way the AC can over 220* coolant temp to provide AC. To verify, clamp off the hetaer hoses it the engine bay so that not coolant goes through and see if that changes your issue to having AC on both sides. If it does then you need a DCCV(dual climate control valve)
Old Aug 9, 2010 | 10:47 AM
Bytor's Avatar
As a follow-up, what if you AC is working fine and then transitions to hot air on all the vents? Turn it off for about 30 seconds and it functions properly again. This happens about twice a week...
Thanks for any follow-up help
BB
Old Aug 9, 2010 | 11:03 AM
JagV8's Avatar
Bad relay, maybe?
Old Aug 9, 2010 | 11:11 AM
Brutal's Avatar
Originally Posted by bytor
as a follow-up, what if you ac is working fine and then transitions to hot air on all the vents? Turn it off for about 30 seconds and it functions properly again. This happens about twice a week...
bb
ide suspect bad evap temp sensor 1st. If its think(reads) that the evaporator is freezing it will shut off ac and depending on reading give heat. Its a cheap($30) easy part and common issue if you ant to diy without paying someone to try and duplicate and charge you
Old Aug 9, 2010 | 02:20 PM
Mafioso's Avatar
excatly my issue, I changed the Evap temp sensor and all is well. sadly I threw too much money at a $20 fix
Old Aug 9, 2010 | 07:09 PM
Gus's Avatar
Gus
Where is this sensor located?
Old Aug 9, 2010 | 07:41 PM
Gus's Avatar
Gus
Is this it??
Attached Thumbnails A/C zone problem !?-evaptempsenson.jpg
Old Aug 10, 2010 | 02:57 PM
Bytor's Avatar
Is this sensor inside, near the key hole, or is it in the cooling system somewhere? Is there more than one Evaporator sensor?
Thanks for any help you can provide...
BB
Old Aug 10, 2010 | 04:49 PM
Brutal's Avatar
is this sensor inside, near the key hole, or is it in the cooling system somewhere? Is there more than one evaporator sensor?
Bb
driver side of the ac box about above your right thigh sitting it the seat. Its a white sensor and 2 wires. Pop it out with a small screwdriver to pop out of the case. The new 1 snaps in and reconnect the wire connector. I have changed 1 already today for a compressor short cycling. If you buy the new 1 youll easily identify it.
Rivguy
Dec 4, 2020 07:55 AM
Dicque
Sep 19, 2015 12:53 PM
Saturbo
Sep 8, 2015 07:35 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
