Camshaft position encoder changing
Old Nov 28, 2020 | 08:34 AM
Motorpot's Avatar
Default Camshaft position encoder changing
Hello,
i have a problem with the camshaft with my S-Type 1999.25er 4,0 V8.
i have installed a used camshaft, the number is the same to the original.
unfortunately i have found out that the position encoder is a wrong one.
how can I change it?
Old Nov 28, 2020 | 09:15 AM
motorcarman's Avatar
This TSB is for the AJ26 engine but the idea is the same for the AJ28 engine with 5 lobe reluctor vs the one lobe on the one in the bulletin.
File Type: pdf
Old Nov 28, 2020 | 10:07 AM
Motorpot's Avatar
Ok, this is interesting, unfortunately it does not help me with my problem.
I have to change the reluctor, because the distribution of the reluctor has changed in one MY, the camshaft is the same.
Old Nov 28, 2020 | 07:20 PM
The AJ26 has a ONE lobe reluctor.
The AJ27 has a FOUR lobe reluctor.
The AJ28 has a Five lobe reluctor.
All on the back of the intake cam.
The reluctor apparently can be removed by sliding it sideways and replaced by another?
I never tried it but it seems likely.
Old Nov 29, 2020 | 03:05 AM
Motorpot's Avatar
Ok,
but, help me when i am wrong.
In the S-Type is always the AJ28, right?
The first motors, up to M45254 have the timing ring: NRA2612BA with Five lobe. from M45255 the timing ring is NNE2613DA with 4 lobe.
And that is the problem at the moment, i ned the 5 and have the 4 lobe ring. Even the position of the lobe is absolutly different.
OK, i will make me a tool to disssamble.
Thanks, Volker
Old Nov 29, 2020 | 08:41 AM
Just swap the old 5 lobe to the replacement camshaft?
Remove the 5 lobe to see if the part can be swapped, the original cam is already faulty.
Old Dec 3, 2020 | 11:05 AM
Motorpot's Avatar
Default done
Hello,
I have exchanged the reluctor.
It is only pressed and can be driven out with a few blows.
then i have seen that it was one from the AJ27 wit 4 lobe.
To insert it, heat the camshaft to about 150 degrees and put the reluctor in the freezer, then the two parts can be easily put together.
Greetings, Volker
jayp33625
Apr 16, 2018 12:06 AM
Smudge67
Jan 21, 2018 05:42 PM
kaotikd
Jul 16, 2015 07:06 PM
relaxed00
Mar 10, 2012 04:53 PM
2meke
Sep 21, 2010 05:46 AM
