cat fault light code
Old Jul 27, 2014 | 01:39 PM
ronfarris's Avatar
Default cat fault light code
just changed timing chain and tensinors after charging battery got cat system fault and open boot light
Old Jul 27, 2014 | 06:24 PM
abonano's Avatar
Ron, check your battery voltage. Any voltage below 12.50V is a problem.
Also, what model car do you have?
Old Jul 27, 2014 | 07:43 PM
ronfarris's Avatar
I have a 2001 s type 4.0 with 88,000
cam tensioner broke and replaced with new type tensioners guides and chain
engine runs fine no noise but have a rough idle
any suggestions so now I take it that the cat system has nothing to do with the engine
Old Jul 27, 2014 | 07:56 PM
QuartzSTypeR's Avatar
Its a suspension problem.
Old Jul 27, 2014 | 08:11 PM
ronfarris's Avatar
any suggestions on what to check next for the rough idle
Old Jul 27, 2014 | 08:37 PM
No trouble codes? Definitely the battery as mentioned, but likely some sort of vacuum leak.
Old Jul 27, 2014 | 09:10 PM
ronfarris's Avatar
could I have a weak coil causing the rough idle and how can I check for a weak coil
Old Jul 27, 2014 | 09:47 PM
abonano's Avatar
with a COP (coil on plug) tester. Ford also has a coil "stress" tester, but you will find a COP tester will point out the coil(s) that are acting up.
About $80 - $100 on Amazon
Old Jul 28, 2014 | 01:58 AM
JagV8's Avatar
After standing overnight and WITHOUT starting engine, what is battery voltage?
philwarner
Oct 4, 2024 01:37 PM
Jpav27
Jul 31, 2022 06:43 AM
02jagstype
Sep 4, 2015 08:20 PM
rachelstr
Sep 3, 2015 12:59 PM
OkieTim
Sep 2, 2015 12:48 PM
