CD Changer Questions
Old Jun 24, 2009 | 09:09 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
Default CD Changer Questions
'06 3.0 without the item in question. There is the recess in the trunk with door and nothing else. I'm entertaining the idea of adding such a unit.
A cursery look shows no holes or what could pass as hidden-behind-the-material mounting brackets.
Are these cars prewired for these items and if so, where might they be?
I did a search, but found nothing there answering my questions.
Or am I just plain out of luck
Old Jun 26, 2009 | 09:30 AM
JOsworth's Avatar
There are mounting points behind the liner. Also, the harness will accept the changer, in other words, it is prewired. Here is the tough part. From the looks of a "factory" equipped car, they probably used a different liner. In order to add the changer you will have to cut it out. I'm sure that is also what the dealer would do, since it can also be bought as an accessory.
Old Jun 26, 2009 | 08:50 PM
Jayt2's Avatar
Veteran: Navy
Thanks Jeff, now to do some taking apart of the liner (carefully) and looking around. Then to find a unit, sure hope it's a plug 'n play system.
Old Jul 4, 2009 | 10:49 AM
Jayt2's Avatar
Veteran: Navy
I recently called the local dealer to find out the cost of a changer and associated labor. Uhhhhhhhhh $1100-1200. That ain't a gonna happen.
Soo, yesterday, I went to the local Pic-A-Part looking for the "needle-in-a-haystack". A late model S-Type with the changer (I can dream can't I ???). Of course, nothing there.
BUT, that parking lot had more cars in it than I have ever seen. It's about 2 acres and it was about 80% full.
A sign of the times ?? Probably..
Time to start callin the other yardes...
Old Jul 4, 2009 | 12:02 PM
searanch's Avatar
Cool
...you should be able to pick up a used one with cartridge on eBay for $200 or less
Old Jul 4, 2009 | 02:15 PM
JOsworth's Avatar
in addition to ebay, try car-part.com , see who has a stereo for the year car you have, then call the yard to see if it also has a changer.
Old Jul 4, 2009 | 03:59 PM
Thermo's Avatar
Veteran: Navy
JayT2, a lot of the wrecking yards are part of a network and you can input your request for a part (CD Changer in your case) and if someone has a car with a changer in it, they can pull it out and send it to a yard close to you. I can garantee that it will be less than what the dealership wants. Can probably even get the necessary liner parts too as part of a "package deal". As for what it would cost, that is very dependent on what the originating yard thinks it is worth.
I normally find that going with an aftermarket unit is normally much cheaper. Granted, I can understand the desire to maintain the factory pieces.
Old Jul 4, 2009 | 08:23 PM
Jayt2's Avatar
Veteran: Navy
Thank you for all of your responses.
It's a lease car so I don't/can't put too much into it since I'll only have it another 3 years unless I buy it then. (My first year anniversary was last Sunday).
I thought of an aftermarket unit, but the dealer said it was connected by fiber optics and will need to be programmed by the dealer. Hence, I'll probably have to stay with a factory one.
I will be contacting those places, but I've heard a few negative things about ebay..(I belong to another auto site and a couple of guys are having trouble right now with their transactions).
Old Jul 4, 2009 | 10:18 PM
Thermo's Avatar
Veteran: Navy
JayT2, as for E-bay, all that I can recommend to you is before you purchase anything, send the seller a question about their return policy and only bid on those items where the seller responds back that they have a 100% return policy if the item is dead on arrival. That way, should anything happen, you can shove that e-mail back in their face and get your money back. I would also recommend waiting say a week after receiving the new CD changer before submitting any feedback. That way, if you end up fighting with them, you can submit the appropriate feedback.
As for an aftermarket unit, what I would probably tell you to do is to mount it else where in the car. I know for my car, because mine has the built in Navigation, I am more than likely going to get rid of the ashtray and mount a single DIN radio there and then run the other aftermarket stereo stuff from that point. Granted, being a lease vehicle, might be more hassle than it is worth. Up to you. I know for me, music is a vital thing that I must have in a vehicle.
Old Jul 6, 2009 | 06:01 PM
Jayt2's Avatar
Veteran: Navy
Thermo, documentation is keenly understood when lifes nuisances pop up.
Music in a car is a must here also. Ima still lookin around.
Dz1rfj
Jul 17, 2018 10:29 AM
captbob73
Oct 24, 2015 05:49 PM
texaspete
Sep 10, 2015 08:34 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
YycXJS
Sep 7, 2015 09:58 AM
