Changed My Battery and My Jag Won't Start!
Old Sep 9, 2014 | 12:46 AM
GVorderstrasse's Avatar
Default Changed My Battery and My Jag Won't Start!
I have a 2000 Jaguar 4.0 S-type. I have never had problems in the past. I have under 140,000 miles on it and it's garaged daily. I changed the battery and now my car won't start. All my guages in the instrument cluster are dead. The only lights that come on now when I put my key in the ignition is the airbag symbol. Here's a list of things that don't work now.
Wipers
Turn signals
The delay night lamps (they come on without the delay switched to that side)
No heads up messages displayed in the cluster anymore.
Also when I attempt to start the car I get one shot before I have to take the key completely out of the ignition to repeat another attempt. I checked all three fuse locations and nothing is blown. The car turn's over, but doesn't start. Sounds like it's not getting fuel. I have gas in the car and the battery is new and charged all the way. Does the instrument cluster control all these things that have failed to opperate, even starting the car? I'm all ears to ways to check, reset, or bypass this in order to get my car working again.
Thanks!
Old Sep 9, 2014 | 02:32 AM
Welcome to the forum GVorderstrasse,
I've moved your question from JagV8's Acronym thread to a new one of your own.
Old Sep 9, 2014 | 02:51 AM
JagV8's Avatar
It sounds the same as a dead battery so check as if it's that:
is it not quite connected properly?
what voltage does it read? (should be 12.6V or so)
do you get the same (near enough) voltage at the fuse panels e.g. in engine bay
what might you have disturbed or nudged during the fitting?
New batteries often come partially discharged (I hate that!) and you get what you're getting.
Old Sep 9, 2014 | 12:02 PM
Default Not the Battery
I cheched the battery this morning and it's higher than 12v. The car sounds very strong and want's to turn over. I checked all fuses and connections. Its a relay or something. What are the typical symptoms of a instrument cluster failure? Is it everything that I mentioned? I'm still looking.
Old Sep 9, 2014 | 12:19 PM
WhiteXKR's Avatar
Was a jump start attempted after your old battery died?
Old Sep 9, 2014 | 07:59 PM
Don B's Avatar
It would be worthwhile to measure the voltage at the battery while cranking the engine. Jaguars do not like low voltage and if it sags too low while cranking the Engine Control Module (ECM) will not trigger the ignition to fire.
It might also be worth checking the battery negative cable where it attaches to the body, which forms a principle ground for the entire car. It's possible that if that junction was corroded, disturbing it while replacing the battery may have increased its electrical resistance.
Please forgive the following obvious questions but we may as well rule them out:
Is the new battery of the correct size (form factor)?
Is the Cold Cranking Amps (CCA) rating of the new battery equal to or greater than that of the old battery?
Are both battery cable terminals sparkling clean, free of any oxidation or corrosion, and fully tightened but not overtightened? Was one of the terminals cracked while installing the new battery?
Cheers,
Don
BrentGardner
29
Dec 16, 2024 12:13 AM
Drew2006
Nov 24, 2015 11:14 AM
cheaperts
Aug 30, 2015 06:48 PM
Drew2006
Aug 28, 2015 04:22 PM
Tony Bow
Aug 28, 2015 05:17 AM
