Code P1857
Old Aug 21, 2007 | 07:53 PM
Default RE: Code P1857
Hey there momsS.................There's a very useful thread on codes in the FAQ section that covers most of the codes if not all of them.
Sods law says that your's aint there, but have a look anyways bud.
In the meantime......Anyone else help a brother out?
Jim
Old Aug 21, 2007 | 07:59 PM
bigdreams05's Avatar
Well, I had to do a bit of research since this code wasn't on Racers list. I've since updated the list.
P1857 Transmission Transfer Case Contact Plate 'C' Short Circuit To Ground
Never heard of such problem...might be common, might not. We'll let the techs help out.
Old Aug 21, 2007 | 08:03 PM
P1587 Throttle Control Unit Modulated Command Malfunction
Old Aug 21, 2007 | 08:06 PM
ORIGINAL: momsS
Looked it up "P1587 Throttle Control Unit Modulated Command Malfunction "
what causes this??? any takers?
thanks
Thats a Jag tech question bro I reckon.
Jim
Old Aug 21, 2007 | 08:12 PM
Probably doesn't get you much further forward but here's a breakdown of the characters within the codes for you
Jim
The first alpha character identifies the system generating the code P = Powertrain
B = Body
C = Chassis
U = Undefined
The second digit says if the code is generic - same for all OBD-II systems - or manufacturer specific
0 = Generic (zero)
1 = Enhanced (manufacturer specific)
The third digit is sub-system type for that code
1 = Emission Management (Fuel or Air)
2 = Injector Circuit (Fuel or Air)
3 = Ignition or Misfire
4 = Emission Control
5 = Vehicle Speed & Idle Control
6 = Computer & Output Circuit
7 = Transmission
8 = Transmission
9 = Reserved
0 = Reserved
Old Aug 22, 2007 | 07:29 PM
jag_genius's Avatar
You need a throttle body... $$$$$$$$$$$ 1500.00-2000.00 depends where you live...
check out my store ... new lambs WOOL FLOOR MATs and used 04 xj floor mats.
Old Aug 23, 2007 | 05:44 PM
If Jag genius is correct moms and he's usually pretty on the ball why not also try checking out Ken@britishparts
Jim
philwarner
Oct 4, 2024 01:37 PM
philwarner
25
Jun 26, 2021 05:43 AM
bdboyle
Sep 16, 2019 05:58 PM
Terry H
Jul 4, 2017 05:48 PM
JCam
Oct 23, 2016 08:27 PM
