Code reader
I bought a elm327 code reader for my 2003 S-type 3.0 and doesn't work on the car. I tried it on my Volvo XC90 and it works just fine. I even tried ones from advanced auto and they don't work either. Any advice?
Did you get a v2 or v1.# other people have reported that the later versions don't always work with the s type. When I was at the emission test with my 2003 3.0 they could not get 2 OBDII readers to work, it was only when they connected one that they reserved for the heavies (trucks) were they able to connect and do the emission test.
I have an ELM 327 that works flawlessly on my 2004 XK8 wits the Torque Pro program. I recently got a 2008 S-Type and the ELM 327 would not work on it until I switched over to the Dash Command program. Dash Command works on both cars.
If your elm will work with a laptop you can also try the full version
here is the link to the demo version
EOBD-Facile : OBD2 software for car diagnostic - Outils OBD Facile
It is the program that I use.
Because no one's reader is reading codes from the OBD socket, there is either a wiring issue with the OBD socket, or the fuse (if there is one; check your owner's manual) is blown.
+1 Nice work Ducmon. Logically, the fuse is the very first thing I would check.
