Code reader
Old Apr 10, 2017 | 10:02 AM
FLStype's Avatar
Default Code reader
I bought a elm327 code reader for my 2003 S-type 3.0 and doesn't work on the car. I tried it on my Volvo XC90 and it works just fine. I even tried ones from advanced auto and they don't work either. Any advice?
Old Apr 10, 2017 | 10:10 AM
JagV8's Avatar
Fault find the OBD socket (aka DLC). Get workshop manual to help - free download.
Old Apr 10, 2017 | 10:12 AM
Ducmon's Avatar
Did you get a v2 or v1.# other people have reported that the later versions don't always work with the s type. When I was at the emission test with my 2003 3.0 they could not get 2 OBDII readers to work, it was only when they connected one that they reserved for the heavies (trucks) were they able to connect and do the emission test.
Old Apr 10, 2017 | 11:45 AM
FLStype's Avatar
It was the 1.5 version.
Old Apr 10, 2017 | 11:58 AM
JagV8's Avatar
Definitely troubleshoot the car.
Old Apr 10, 2017 | 12:14 PM
FLStype's Avatar
When I go to a local shop. Their code reader works.
Old Apr 10, 2017 | 01:16 PM
JagV8's Avatar
So do the elm327 normally - but not on your car.
Your choice what you do.
Old Apr 10, 2017 | 02:28 PM
FLStype's Avatar
I'm just trying to find one that works. I don't want to pay a shop to give me the codes.
Old Apr 10, 2017 | 04:54 PM
Ducmon's Avatar
What program did you use?
Old Apr 10, 2017 | 05:16 PM
daro31's Avatar
Default Code reader problem
I have an ELM 327 that works flawlessly on my 2004 XK8 wits the Torque Pro program. I recently got a 2008 S-Type and the ELM 327 would not work on it until I switched over to the Dash Command program. Dash Command works on both cars.
Old Apr 10, 2017 | 05:30 PM
FLStype's Avatar
Ok I'll try that.
Old Apr 10, 2017 | 06:22 PM
FLStype's Avatar
The torque app.
Old Apr 11, 2017 | 01:31 PM
Ducmon's Avatar
Try the EOBD-Facile app it works on my 2003 v6.
Old Apr 11, 2017 | 05:50 PM
FLStype's Avatar
Ok, I'll try it. I haven't been successful with finding a code reader that works.
Old Apr 11, 2017 | 06:41 PM
JagV8's Avatar
Because 100s have worked OK we know it's something about your car or the tool you've bought (or its software). Hopefully you'll figure it out.
Old Apr 12, 2017 | 05:18 AM
Ducmon's Avatar
If your elm will work with a laptop you can also try the full version
here is the link to the demo version
EOBD-Facile : OBD2 software for car diagnostic - Outils OBD Facile
It is the program that I use.
Old Apr 13, 2017 | 01:16 PM
Jumpin' Jag Flash's Avatar
From: Pawleys Island, SC USA (formerly from Tabernacle, NJ USA)
+1
Because no one's reader is reading codes from the OBD socket, there is either a wiring issue with the OBD socket, or the fuse (if there is one; check your owner's manual) is blown.
Old Apr 14, 2017 | 09:43 AM
Ducmon's Avatar
Passenger footwell fuse box F6 10 amp mini is for the OBDII connector in 2003 cars
Old Apr 17, 2017 | 11:16 AM
+1 Nice work Ducmon. Logically, the fuse is the very first thing I would check.
