Connector for rear deck woofers?
Old May 2, 2011 | 11:06 PM
phaelax's Avatar
Default Connector for rear deck woofers?
I'm installing some new subs(two 12") and going to disconnect the existing 8" woofers in the rear deck. The plan was originally to just tap into those wires but then I saw the white plastic connectors. Anyone know where I could find a wire that plugs into those so I don't have to clamp onto the existing ones? (hopefully this makes sense)
Old May 3, 2011 | 01:13 AM
jag79's Avatar
Ummm...FYI the stock rear deck subs are 6.5" not 8". I put in two 8" free air subs in the same location with some modding of course. Just cut the connector off, that's all I did to expose the pos & neg wires.
Old May 3, 2011 | 01:37 AM
phaelax's Avatar
I read somewhere someone had put in 8", probably why I said that. I was hoping not to cut them incase I ever wanted to go back to stock.
Old May 3, 2011 | 07:14 AM
phd12volt's Avatar
i didnt cut my rear deck. I added the 8's with a false panel that plays through the factory holes.
It sounds like poop though without an amp.
Old May 3, 2011 | 08:01 AM
Greenhornet's Avatar
I had bought new Kicker 6.5 inch Sub, and replaced the Stock Subwoofer, but also added a 10" sub/box in Trunk, got carried away. You can get a Sub in the size 6.5, just gotta look around. The 6.5 sub sounded good, I just wanted more.
Old May 3, 2011 | 08:29 AM
androulakis's Avatar
No luck on the other side of that connector in the aftermarket. Just leave some wire on the connector end when you cut it, and if you want go back to stock, just splice / solder it all back together.
Take care,
George
Old May 3, 2011 | 08:55 AM
jag79's Avatar
...Take a look here. This may give you a better idea.
https://www.jaguarforums.com/forum/s...ncluded-52507/
Good Luck.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
YycXJS
Sep 7, 2015 09:58 AM
avern1
Sep 6, 2015 04:22 PM
Sprayall
Sep 3, 2015 07:49 PM
