coolant hose quality
Old Aug 19, 2014 | 05:40 PM
hifipm's Avatar
Default coolant hose quality
Gentlemen I have just gone through the process of having all of my coolant hose's replaced on my '03 STR ( after a couple of failures-though it was a good idea) . I have now had 2 of the brand new hoses fail in the first few weeks!! Both hoses failed near the clamp and the second one came completely apart! Has anyone had this experience? Is there anything my mechanic is doing wrong to make this happen? He services all kind of Jags Audi's BMW and Merc's so is very used to working on imports and has done a great job on all other repairs. He has never seen anything like this before. Anyone else had an issue? I am stumped and have less confidence than before the replacement- thank Paul
Old Aug 19, 2014 | 05:43 PM
jonscot's Avatar
I can't remember the last time I had a new hose fail quickly ... perhaps your shop got a bad batch ... since you say that they have experience, I will not consider the usual failure of clamp/hose overtightening.
Old Aug 19, 2014 | 11:21 PM
plums's Avatar
oem or the dreaded uro?
Old Aug 20, 2014 | 03:10 AM
JagV8's Avatar
Doesn't sound like OEM.
Old Aug 20, 2014 | 11:26 AM
David_h's Avatar
In addition to the hoses, were the clamps OEM or aftermarket worm gear type?
Old Aug 20, 2014 | 01:25 PM
hifipm's Avatar
Default hose failures
Thanks for the replies - yes OEM from the Jag dealer and the clamps appear to be aftermarket worm gear types-could this be the issue? thanks Paul
Old Aug 20, 2014 | 09:17 PM
David_h's Avatar
Yes I think it is possible the clamps were too tight. They do have a sharp edge around the band; certainly so when you compare them to OEM clamps. Maybe go around and loosen each clamp and monitor wear?
Old Aug 20, 2014 | 09:57 PM
Robinb's Avatar
I changed all 18 hoses in my STR about 9 months ago. I got (most of) the OEM hoses from eBay, and my indie did the work, using OEM clamps.
Only 1 problem, caused by a hose that was too close to a moving belt. No problem in neutral, but the slight engine block movement when the car was in gear brought the belt into contact with the hose. One day later, a leak from the cut hose.
Wahooesprit
Dec 23, 2019 02:01 PM
duecedriver
Dec 25, 2015 11:47 AM
Lannyl81
Sep 19, 2015 08:07 PM
1100me
Sep 7, 2015 06:26 AM
