Coolant leak
Old Jun 27, 2025 | 07:10 AM
turkay's Avatar
Default Coolant leak
Hello,
I would like some assistance maybe someone would have an issue with the same type of coolant leak, I cannot seem to understand where it's leaking from, I got the idea that it's leaking from that tiny hole, but from where is that tiny hole? Is it from a radiator?
Old Jun 27, 2025 | 12:17 PM
xalty's Avatar
radiator side tank is cracked. always right side
drive with the cap loose until you get a new radiator
Old Jun 27, 2025 | 12:59 PM
+1 on that.
Old Jun 27, 2025 | 06:37 PM
kr98664's Avatar
Beg, borrow or steal a cooling system pressure tester. This is the doohickey that looks like a bicycle tire pump and connects in place of the reservoir cap. You manually pump up the cooling system to the rating on the cap. If there are any external leaks in the cooling system, you will be able to find them.
The big advantage of the pressure tester is you put the system under much more pressure than merely running at idle. Many leaks will not be apparent at the reduced system pressure present at idle. With the engine cool and switched off, you can poke around with no risk of burns nor danger from moving parts.
If you'd rather not spend the money to purchase a tester, some auto parts stores have free loaners.
Old Jun 28, 2025 | 05:31 AM
turkay's Avatar
Ok, so I went to the mechanic and we removed the engine undertray, from the looks of it the radiator that is leaking is the one marked with blue, can anyone tell me from A to Z which radiator is which? Tried finding a schematical sheet but to no luck.
Attached is a photo from an Ebay listing.
Also the leak has gotten far worse.
Old Jun 28, 2025 | 10:59 AM
clubairth1's Avatar
Community Influencer
Go to Ebay and please get a manual for your car!
The discs are cheap and will be very useful.
Old Jun 29, 2025 | 04:03 PM
turkay's Avatar
I will most likely go and hang myself hahahhaha 😂😂
Supercharger radiator about 2000€ brand new haven t been able to find a used one. Absolutely brilliant.
Car Crazy
Oct 30, 2023 10:59 AM
Adventurous x
Feb 7, 2023 11:14 AM
mpasiuk
24
Mar 14, 2022 10:12 PM
mhannaoui
Dec 28, 2020 03:07 AM
Drak
Dec 11, 2015 03:45 PM
