Cougg splutter backfire..rich petrol smell..
Old Mar 10, 2016 | 04:45 AM
Optimeyes's Avatar
Default Cougg splutter backfire..rich petrol smell..
Optimeyes , Today 04:00 AM
I recently put new radiator hoses on my 2002 S type and accidently broke the Vacume pipe that runs along the engine to a shoulder at the back ..i replaced it with rubber hose and jubilee clips, Is this OK?. Also ever since doing this I have had problems with missfiring and lack of power and smells verh very rich using loads of petrol...could this be why, or is something else wrong..
Old Mar 10, 2016 | 05:02 AM
JagV8's Avatar
Sounds likely the problem. Best to fit the right pipe.
If left running like that you'll probably destroy one or both cats.
Old Mar 10, 2016 | 05:37 AM
I recently put new radiator hoses on my 2002 S type ....
Welcome to the forum Optimeyes,
I've deleted your duplicate post about this issue in Other Jaguar Models / Concepts / Replicas forum.
Old Mar 10, 2016 | 07:05 AM
joycesjag's Avatar
What engine? Post codes.
Old Mar 10, 2016 | 07:23 AM
Optimeyes's Avatar
Its a 3 ltr v6 petrol
Old Mar 10, 2016 | 10:29 AM
kr98664's Avatar
Take a look at the far end of run containing the hose you replaced. The portion you replaced is probably just fine. This current fault is likely to be something else that got disturbed, i.e. a flexible section on the far end of the rigid pipe to which you installed the new piece of hose.
These engines are notorious for vacuum leaks caused by old flex couplings giving up the ghost. Find and fix the fault and you should be good as new.
Old Mar 10, 2016 | 11:04 AM
Optimeyes's Avatar
Default Hose inside hose
Originally Posted by kr98664
Take a look at the far end of run containing the hose you replaced. The portion you replaced is probably just fine. This current fault is likely to be something else that got disturned, i.e. a flexible section on the far end of the rigid pipe to which you installed the new piece of hose.
Thanks..Do you mean the corner piece that serms to just push inside another piece...is that supposed to be like that ?
Old Mar 10, 2016 | 01:22 PM
joycesjag's Avatar
Most likely you will find your answers in this link:
https://www.jaguarforums.com/forum/s...ics-faq-52720/
Old Mar 16, 2016 | 01:46 PM
Optimeyes's Avatar
Default Fitted top vacume pipe...
New vacuum pipe fitted now and disconnected earth for about an hour. Everything is much calmer...still a little bit of missfire..but nothing like it was...a lotsmoother running too. But no power .....
Can anyone tell me what the shoulder where the vacuum pipe goes into the block at the back is supposed to be like..because all I have is a collar of rubber pipe sticking out of the block and the shoulder of the vacuum pipe stuffed into it..not confident it's right, and is nothing like the other plugs that are for breather pipes, although I didn't have a single problem before all this came about so it must have worked somehow...anyone any suggestions.I'm getting stressed lol.....
.thanks.
Old Mar 21, 2016 | 11:21 AM
NBCat's Avatar
.thanks.
If I understand you correctly, you must be referring to the hose fitted to the crankcase breather underneath the lower inlet manifold. There are no clamps, or other securing devices, used to hold this hose in place.
As mentioned earlier, any misfire can cause irreparable damage to the catalytic converters. Do not operate the vehicle if the MIL is flashing as catalyst damage is occurring.
Old Mar 21, 2016 | 11:34 AM
Optimeyes's Avatar
Hi..thanks for that...Ues I know ablut the cats...and no...I am not running the car yet...I have a click at home mechanic comimg on Wednesday....thanks again...Phil
klfong
Jun 9, 2021 07:54 AM
MissyBeeS
Apr 6, 2016 08:25 PM
ukdeluded
17
Mar 15, 2016 02:27 PM
Unhingd
Mar 6, 2016 08:44 AM
Tonyj
Mar 5, 2016 02:44 AM
