Could REALLY use any help right now!!
Old Mar 22, 2010 | 07:53 PM
fergs03R's Avatar
Default Could REALLY use any help right now!!
Am in the garage and stuck....all i am trying to do is put a new sc belt on and I cant figure out how to move the tensioner.....the bolt is 13 mm and is almost impossible to get any type of wench/socket on, and then to have any leverage, it will not move, even with a 2 ft bar attached to the handle of a 1.4 drive socket(all i could fit)
I cant believe i need to put this thing back together with no progress....its never never happend to me before ever on a car project... I cant accept the failure. Its a friggin belt for gods sake....elementary stuff!!
Am i missing something, doing it wrong or is my tensioner actually siezed??
Many thanks for any insight
Old Mar 23, 2010 | 05:56 AM
JOsworth's Avatar
Sorry this is the next morning...Then again it would be too late anyway...
I had the same problem working on the Grand Caravan... Zero room to move the tensioner.
I went to Sears and picked up a belt tensioner tool..Basically a bar with different hex adapters and such...That thing works great...
This is it.
Old Mar 23, 2010 | 10:39 AM
redzed's Avatar
Just had a look at the JTIS and the SC belt tensioner is almost identical to the tensioner on the 3.0.
I've done this myself and it's very easy if you can get access. There is no need at all to remove the bolt. There should be a 1/2" sq hole in the tensioner arm, it's just a matter of putting a 1/2" drive in there and rotating the arm until you release the tension on the belt then you can remove it.
Old Mar 24, 2010 | 10:46 AM
redzed's Avatar
You take time out to help and you don't even get a grunt back in return, talk about bad manners !!!
Old Mar 25, 2010 | 10:08 AM
Panthro's Avatar
Thumbs up
On behalf of the OP, and all those who may have to deal with a problem like this in the future, I thank you. (Don't want people to stop helping out on this forum, ya know?)
Old Mar 25, 2010 | 10:31 AM
Jon89's Avatar
Plus, it's only been a couple of days since the OP posted about his issue. He may not have had the chance yet to get back to the forum to update his thread. Folks go out of town, get busy with work, get sick, get sidetracked by other things, etc. etc. etc.
Old Mar 25, 2010 | 10:42 AM
H20boy's Avatar
Only been 3 days, it may take longer to get to it and post the results. Now, if it were 3 months, I'd understand a bit of disappointment. I'd wait a bit longer and lets see how the OP fairs.
H20boy's Avatar
Jon, great minds.... and all that.
Old Mar 25, 2010 | 11:14 AM
JagV8's Avatar
STR SC belt remove/fit (the Air Deflector is the engine undershield):
File Type: pdf
