Cruise Control Cancelled
Old Mar 29, 2016 | 02:20 PM
Rob Edge's Avatar
Default Cruise Control Cancelled
Hope someone can shed some light on this. I have a 2003 2.5V6 which is fitted with cruise control. When I press the set button you can feel it engage but within seconds you get the message "Cruise Cancelled". Code read it tonight and the only code is P111 which is system pass. I would bank on it being the brake switch but I am open to suggestion. All the other steering controls work normally.
Old Mar 29, 2016 | 03:07 PM
JagV8's Avatar
You may well be right but it could also be the cruise cancel button - there'd need to be a bad connection or some such.
I don't know if there are yet other ways it could happen.
Old Mar 30, 2016 | 02:14 AM
Rob Edge's Avatar
Cancel button first then.
Old Aug 14, 2017 | 10:03 PM
Amir Afzul's Avatar
Hi Rob
Having a similar issue, the CC cuts out as soon as it begins. Did you work out the fault in the end?
Old Aug 15, 2017 | 12:18 AM
Rob Edge's Avatar
Originally Posted by Amir Afzul
Hi Rob
Gave up in the end and bought a Jeep.
Old Aug 15, 2017 | 12:21 PM
Golan's Avatar
Does your car have adjustable steering and peddles?
Old Aug 15, 2017 | 12:58 PM
Amir Afzul's Avatar
Yus.
Old Aug 16, 2017 | 05:22 PM
Golan's Avatar
I only say this because if the pedals are too far back the brake pedal won't be able to return to it's resting place and it'll stop the cruise from working.
Rocky15
Apr 12, 2018 09:41 AM
roberthornsey
Mar 11, 2016 08:38 AM
razorboy
Mar 9, 2016 09:20 PM
Geofflvmyjag
Mar 8, 2016 12:18 PM
Doug
Mar 8, 2016 08:01 AM
