Cylinder numbering (4.2L)?
Old Nov 2, 2024 | 06:51 PM
mikesbaron's Avatar
Default Cylinder numbering (4.2L)?
Bear with me, working from my phone-can't find or get a diagram to load showing cylinder numbering.
Can someone help me out with a photo that shows for 2003 V8 base model?
Old Nov 2, 2024 | 07:32 PM
Here you go!
Old Nov 2, 2024 | 10:19 PM
mikesbaron's Avatar
Thank you very much.
You staying warm down in AZ?
Old Nov 3, 2024 | 12:44 AM
mikesbaron's Avatar
One important question,
How do I know if I have current 2003 or newer AJ V8? What if it's possible that I have engine manufactured before 2003 even though my car is listed as 2003 it could have been manufactured in 2002 and have a 2002 engine. Where is the 4.2 l only made in 2003 forward?
Old Nov 3, 2024 | 07:30 AM
User 42324's Avatar
How ? Because you have a 4.2 not a 4.0.
Old Nov 3, 2024 | 08:13 AM
S-Type Owner's Avatar
Most of the world got a 2002.5 model, which introduced some significant changes to the S-type. The 2002.5 model (X202) went to market as a 2003 model in the U.S.A.
Old Nov 3, 2024 | 11:59 AM
kr98664's Avatar
Originally Posted by mikesbaron
How do I know if I have current 2003 or newer AJ V8? What if it's possible that I have engine manufactured before 2003 even though my car is listed as 2003 it could have been manufactured in 2002 and have a 2002 engine...
The big question is whether you have a pre- or post-facelift model. That cutoff point is when the major changes occurred, not specifically the date of manufacture. For the most part, the model year (2002 vs. 2003) is a something of a marketing designation.
Does your car have the 5 speed transmission? Then it's pre-facelift. 6 speed? That's post. If unsure which, look at the shift lever bezel. For a pre-facelift car, the number at the aft left corner is 4, and D=5. Post-facelift, the number at the corner is 5, and D=6.
Old Nov 3, 2024 | 01:42 PM
User 42324's Avatar
The 4.2 S-type only came with the ZF 6 speed box.
Old Nov 3, 2024 | 05:26 PM
It's an STR so will be post 2002.5 his sig says 2006 so I wouldn't worry about pre 2003.
Old Nov 4, 2024 | 04:07 AM
User 42324's Avatar
His post mentions it's about a 2003 4.2 V8 base model.
Old Nov 4, 2024 | 05:13 AM
Your right, I missed that but the same diagram will apply.
Old Nov 4, 2024 | 08:49 AM
mikesbaron's Avatar
I've got 5 on the left of my automatic shift column. D=6.
Moppie64
Aug 9, 2022 10:25 AM
XJRfan
Aug 3, 2022 01:26 PM
Reverend Sam
Jun 25, 2021 01:53 AM
Toyroom
Jan 21, 2013 03:16 PM
mshrull9988
May 12, 2012 07:23 PM
