Does anyone know where the crankshaft sensor is located on a 2004 s type v6
Old Jul 5, 2019 | 08:45 PM
adamsavey's Avatar
Angry Does anyone know where the crankshaft sensor is located on a 2004 s type v6
Spent two hours looking for it. I also searched online but can't find the location of the crankshaft sensor for a 2004 s type v6.
Appreciate any help...thanks
Old Jul 6, 2019 | 02:41 AM
JagV8's Avatar
Move to S-Type forum and get the free workshop manual.
Old Jul 6, 2019 | 03:45 AM
Welcome to the forums adamsavey,
I've moved your question from General Tech Help to S-Type forum. This is the place to post technical questions about your model.
Old Jul 6, 2019 | 09:42 AM
motorcarman's Avatar
The CKPS is on the right forward side of the engine block. The electrical connector is shown on page 40 of the S-Type powertrain into booklet S-Type POWERTRAIN_JJM101517-92.pdf
Crankshaft Position (CKP) Sensor
Crankshaft position and rotational speed are
sensed from a steel timing ring keyed to the front
end of the crankshaft immediately behind the
front cover. The timing ring has 36-1 teeth, ie one
missing tooth, which are angled slightly forward
and bent at right angles to provide a sensing area
for the inductive sensor. The sensor is positioned
in the front cover, to the side of the crankshaft
damper, at approximately 20 degrees to the plane of the
timing ring.
Old Jul 6, 2019 | 07:29 PM
adamsavey's Avatar
Default thanks
thank you for your help
Old Jul 6, 2019 | 07:31 PM
adamsavey's Avatar
Thanks so much!
Old Jul 7, 2019 | 01:02 PM
As a newbie you won't yet be able to download the very useful attachment motorcarman included in his post #4.
Here's the engine control locations graphic from the Workshop Manual:
See item 7.
Old Jul 7, 2019 | 02:55 PM
adamsavey's Avatar
Graham...thank you so much, that helps even more since I wasn't sure I had the right spot. Have a great day!
muttony
Apr 7, 2019 10:30 PM
Carlos Mijares
Nov 2, 2016 03:10 PM
Smoke Em
Aug 7, 2016 04:44 PM
JessN16
Jun 12, 2016 06:04 PM
