EGR Exhaust Gas Recirculation Code P0401
Old Nov 7, 2014 | 07:05 AM
Rob Reilly's Avatar
Default EGR Exhaust Gas Recirculation Code P0401
2000 S-Type 3.0 V6 with 205,000 miles
I'm getting OBD code P0401 Exhaust Gas Recirculation Insufficient Flow.
I reset it, and it comes back in 50 to 100 miles.
So far I have:
inspected all vacuum hoses, found no deficiencies;
checked electrical signal at electrically operated EGR vacuum regulator solenoid valve located on the LH side of the intake manifold;
checked fuse #6, replaced relay #14 which supplies power to EGR solenoid valve;
checked vacuum on input side of this valve (17.5'', 44 cm Hg), and at vacuum operated EGR valve connecting the EGR pipe to the intake manifold (1'', 4 cm);
cleaned vacuum operated EGR valve;
replaced EGR vacuum regulator solenoid valve;
checked pressure at both Differential Pressure Feedback Electronic DPFE sensor hoses (fluctuates about 1 psi 0.5 kg/scm);
replaced DPFE sensor located on the back of the intake manifold;
replaced vacuum operated EGR valve;
bypassed regulator solenoid valve with jumper hose and tried running for a few days with EGR valve wide open, thought it might blow out the EGR pipe;
removed 5/8'' diameter EGR pipe from exhaust manifold,
learned it has a 17/64'' (7mm) diameter orifice inside between the two small DPFE pipes, blew it out both directions including the small pipes with sandblaster using about 2 pounds (1 kg) of sand, used wire bottle brush to clean inside port on exhaust manifold;
Still getting code P0401. No other codes, car runs perfect.
What have I missed? What's left? Does anybody have any ideas?
Old Nov 7, 2014 | 10:23 AM
tbird6's Avatar
With your high miles I would change the EGR valve. It may be working but you can't really tell.
No holes in the EGR tube?
Old Nov 7, 2014 | 11:03 AM
Rob Reilly's Avatar
I did change the EGR valve already, step 9 above.
EGR tube is about 5 years old, no holes.
Old Nov 7, 2014 | 11:08 AM
tony1963's Avatar
You either have the pipe carboned up or the intake carboned up.
Old Nov 7, 2014 | 11:30 AM
Rob Reilly's Avatar
Thanks. Step 11 was I sandblasted through the pipe, 100 psi with plenty of sand both directions, seems to have plenty of flow through. The pipe has only been on there about 50,000 miles. (I saved the old one which had a broken exhaust end, that's how I learned about the orifice, cut it open.) I also wire bottle brushed the ports on the intake and exhaust manifolds. Are you saying to take off the intake manifold and clean it?
Old Nov 7, 2014 | 12:12 PM
tbird6's Avatar
Sorry I missed you replaced the EGR valve already.
Not sure as you have done a bunch of work and still have the code.
If you do get it fixed please let us know because it does not look like a normal EGR failure and maybe related to something else but still triggers the EGR code. Just guessing?
Old Nov 24, 2014 | 02:25 PM
Rob Reilly's Avatar
I think I may have a clue to the problem. Bad electrical connection at the PCM. I tried to trace the wires from the DPFE back to the PCM. They are under the cabin air filter duct. You have to take off the windshield wipers, the plastic panel covering the wiper mechanism, the cabin air filter, and two plastic ducts, and there are three electrical connectors under there. I couldn't get them disconnected, but I wiggled them. After that the engine light stayed off for over a week. It came on again with the same code yesterday. So I think I need to take the PCM out from the inside and clean the contacts.
Old Apr 10, 2018 | 10:54 PM
ivicks's Avatar
Hey, I have the same problem with another code p0420,
my question is,
Would it be safe and okay to drive my car for 500 mile trip without fixing this codes??
Old Apr 12, 2018 | 04:58 PM
abonano's Avatar
So far I have:
To confirm you changed out both the valve and vacuum solenoid? Why did you have to change the relay?
You might need to clean out the passages in the manifold itself.
silkcat
Jan 18, 2025 04:29 AM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Dickie_L_J_O
Sep 13, 2015 07:44 AM
tonyforman
Sep 10, 2015 07:23 PM
Bowman
Sep 3, 2015 03:17 PM
