Engine Check Light Turns on when I use Heat
Old Mar 20, 2017 | 01:22 PM
Don Bot's Avatar
Question Engine Check Light Turns on when I use Heat
I have a Jag S-Type 2006 ; v8; around 148k miles on it.
During my drive when I turned on the heat , the check engine light got turned on. I went to a good year service and they said they cannot make out the codes. They reset and asked me to get back when it gets turned on.
The next time again when I turned on the heater , again check engine light got tripped on; I got the codes read again from the same place and they said there are a bunch of things. One of them being misfire and stuck me with a 1200$ USD Quote. They turned off the Engine Check light.
After driving 80 Miles, I turned on the heater immediately the dreaded Engine Check light got turned on. I was doing a road trip on sunday and out of no choice drove around 500 Miles after that.
It is obvious that it has something to do with heater and I guess not exactly engine.
Appreciate some idea on what might be wrong. I really don't want to spend 1.2k chasing a ghost.
Old Mar 25, 2017 | 11:05 PM
kr98664's Avatar
Sorry for the late reply here. I missed your query when originally posted.
Can you please get the actual codes, such as P0306, P0388, etc. It sounds like the shop only gave you the generic definitions instead of the Jag-specific codes. The codes are needed for accurate troubleshooting.
If the shop won't cooperate, I'd suggest investing in an inexpensive OBD II scanner of your own. You can go even cheaper and get a very basic code reader, but a scanner is much more versatile and lets you read real-time parameters such as fuel trim and sensor data.
Whatever the fault is, it's tough to foresee it costing $1200.
Old Mar 26, 2017 | 07:31 AM
Jon89's Avatar
Go to a competent shop or get a decent scanner as advised above....
Old Mar 26, 2017 | 08:20 AM
Ducmon's Avatar
As it is an engine code you could get an elm 327 for around tenner just Google it but make sure that it is not v2. I found that type did not work but the earlier models did.
Old Mar 26, 2017 | 09:01 AM
JagV8's Avatar
Being a newer car, any elm327 _should_ work. (Refund if not.)
kmmoore1013
Jul 28, 2013 04:31 PM
ericl007
Dec 14, 2012 03:37 PM
srpope80
Nov 17, 2011 04:06 PM
MLRocafella85
Dec 10, 2010 09:23 AM
