engine locked up 2002 4.0 s type
Old Mar 31, 2009 | 01:42 PM
JagtechOhio's Avatar
Try to rotate the engine by putting a socket on the bolt in the middle of the crankshaft pulley. Turn clockwise.
4.0 engines can lock up as a result of a broken secondary timing chain, or a failed connecting rod bearing. Neither problem can be identified without doing at least some disassembly.
If yours is locked up, you're best off looking for a used engine or selling the car: piece by piece if you can, or in one lump if you have to.
Old Mar 31, 2009 | 03:34 PM
I have to admire your optimisim
Good luck with the sale.
Old Mar 31, 2009 | 03:41 PM
C'mon norri, it's a roller. A high roller, at that.
Old Mar 31, 2009 | 04:03 PM
Brutal's Avatar
YOU NEED TO CHECK THE STARTER AS IVE HAD 2 LOCK UP THE ENGINE TIGHTER THAN...WELL TIGHT. bOTH V8'S SO DROP THE STARTER AND CHECK FIRST
Old Mar 31, 2009 | 04:11 PM
That's a good one...you just saved somebody a car someday.
I'm guessing you wouldn't hear the "clack" when the drive extends, since it's already stuck?
Old Mar 31, 2009 | 05:47 PM
Brutal's Avatar
No, and the first one I swore was the engine, except it would turn either way off the crank bolt. The 2nd was a good customer who called me last year over the weekend. I told he she needed a starter(she let me listen on her phone) and come in monday Ide do it while she waited...well she waited alright...2 weeks till she was at the store and needed a wrecker...and her engine was locked up tighter than...her ex husband
Old Mar 31, 2009 | 06:10 PM
I once had a Rolls Canardly.
They roll down hills and can 'ardly get up the other side
Old Mar 31, 2009 | 06:21 PM
That fits the trend, things have been going downhill pretty steadily around here. At first I thought it was me, then the spammers, but now I think it's because of the jokes. So we're both to blame!
Old Apr 3, 2009 | 01:21 PM
Brutal's Avatar
WELL THEN THAT MEENS YOUR CAR IS TOTALLED. i MEEN I JUST FINISHED A CERT PREOWNED 06 STYPE R WITH 40K ON IT THAT WE SOLD FOR $26K...IVE WORKED ON THIS CAR SINCE NEW AND KNEW THE OWNER WELL, SHE TOOK GREAT CARE OF IT. IF I WAS HAVING A BETTER YR AT WORK IDE HAVE GOTTEN MY WIFE THIS FOR A 50TH B DAY PRESENT......
stanjag
Dec 29, 2024 08:26 PM
h4wk
Nov 27, 2015 05:10 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
brent65622
Aug 26, 2015 08:41 AM
