Engine management light
Old May 1, 2018 | 02:16 PM
Andrewask's Avatar
Default Engine management light
hi, I have a 2004 2.5 v6 s type, the other day the engine management light came on while driving, I checked the self diagnostic test which gave me these readings
Dtc 9689
Inside rearview mirror motor #2 (horizontal) circuit open
9246
Dim panel potentiometer switch circuit failure (airbag or rear view mirror circuits)
E511
CAN - DATA MIS-MATCH (RECEIVED DATA DOES NOT MATCH EXPECTED)
A879
Tilt down switch circuit open (rear view mirror)
E518
Climate control fault flagged
D900
CAN COMMUNICATION BUS FAULT - RECEIVE ERROR
Old May 1, 2018 | 02:21 PM
Andrewask's Avatar
So I borrowed a diagnostic machine and this is what it said
Old May 1, 2018 | 02:23 PM
Andrewask's Avatar
If anybody with some knowledge on this could help it would be brilliant, would love to get to the bottom of the problem, thanks in advance
Old May 1, 2018 | 03:48 PM
docs427's Avatar
that looks like the car wasn't running? Needs to be running if so. Also you have 2 codes stored that you need to get with the scanner, those will probably lead to your problem
Old May 2, 2018 | 01:25 AM
JagV8's Avatar
Ignore them.
They're not current are they?
Any that are will be shown by a normal OBD tool (such as the one you used).
The ETM ones can be and usually are many years out of date. Pity they exist.
No offence but the pics posted just look like aimless messing around. What were they intended to prove or show?
Old May 5, 2018 | 12:15 PM
clubairth1's Avatar
Community Influencer
Yes can you get the codes read at Autozone?
Not sure what to make of all those Snap-On scanner shots?
After you get them read have them erase everything so we can see what codes come back before you start doing anything. Always want to see the codes repeat so we are sure they are real.
Old May 7, 2018 | 02:14 AM
Ducmon's Avatar
Check your battery voltage it should be 12.6 volts anything lower and you can get codes for none existent faults
mick2jags
Europe
Sep 15, 2011 03:54 PM
pegasus3710
May 19, 2011 03:57 AM
Jimbo
XJ40 ( XJ81 )
Jul 15, 2010 09:57 PM
trevor112468
Apr 7, 2010 03:39 AM
PaulH
Mar 1, 2010 02:25 PM
