Engine will not turn over any ideas?
Old Apr 26, 2015 | 08:59 PM
rachelstr's Avatar
Default Engine will not turn over any ideas?
Hi everyone
My 2005 S Type R will not turn over
It has a new battery in and was running fine I went to the grocery store and when I came out I put the key in and turn it and all dash lights work radio windows etc. When I turn it to start I hear a solenoid click but the engine does not crank.
I don't know if this has anything to do with it but it was raining pretty hard here today when this happened.
any ideas would be great.
Rachel
Old Apr 27, 2015 | 01:06 AM
JagV8's Avatar
Put headlights on, measure battery voltage. Expect more than 12.5V
Old Apr 27, 2015 | 08:43 AM
rachelstr's Avatar
Default Update
OK I checked the battery and it is good. I was mistaken when I said earlier that I hear the solenoid click The solenoid is making no sound. It is the relay that is making the click sound when I have someone turn the key and listen to it at the fuse box under the hood.I hear a distinct click sound coming from the relay. But nothing else happens.
I love this car but the problems with it are SOO frustrating.
Old Apr 27, 2015 | 10:17 AM
JagV8's Avatar
Follow Electrical Guide and/or JTIS troubleshooting (free download). There are only a few places where power should be (such that the starter energises) but presumably isn't.
Old Apr 30, 2015 | 07:51 PM
rachelstr's Avatar
Default Fixed
I gave up and had it towed to a shop. He found that a bolt had come loose in the shift linkage and the car could not tell that it was in park.
Old Apr 30, 2015 | 10:11 PM
NBCat's Avatar
The shift linkage bolts are items to be inspected for tightness at every oil change.
Old May 1, 2015 | 07:38 AM
Jon89's Avatar
Yep, that procedure is indeed mandatory. 30 seconds using an 8mm box wrench to snug up those two ZF cable bolts is time well spent....
Old May 1, 2015 | 08:01 AM
JagV8's Avatar
Check 'em as you do each oil change. You're under there anyway
(Except the diesel, I gather.)
Old May 1, 2015 | 02:13 PM
tbird6's Avatar
Glad to hear the fix was easy but sorry you had to go to the shop.
Would have been a free fix if you found it yourself.
bluerdg
Sep 1, 2015 08:07 AM
GreyXK
Aug 31, 2015 05:15 PM
SatanClaus
US Southwest
Aug 31, 2015 11:45 AM
SatanClaus
Aug 29, 2015 09:15 AM
SingBlueSilver
Aug 27, 2015 02:20 PM
