Fault code P1637
Old May 6, 2018 | 04:42 PM
Sifiso Michion Radebe's Avatar
Default Fault code P1637
2005 jaguar stype fault code p1637 after diagnosis
on the massage display says no traction control low fluid abs faulty no Cruze control park brake faulty making beep
help me its been long this going on
Old May 6, 2018 | 06:12 PM
meirion1's Avatar
P1637 indicates an earth or ground fault related to the abs module.
Check earths/grounds behind front headlights.
Be very careful they can break off very easily if corroded.
Old May 6, 2018 | 11:36 PM
Don B's Avatar
Hi Sifiso,
Welcome to the Jaguar Forums! It's great to have you with us.
You can download the Diagnostic Trouble Code Summaries manual at the link below, which gives you definitions and possible causes of each DTC:
Jaguar Powertrain DTC Summaries All Gasoline Models 2004
As you will see in the manual, a possible cause of P1637 is a problem with the Controller Area Network (CAN) circuitry between the Dynamic Stability Control Module (DSCM) and the Engine Control Module (ECM). This can be caused by looseness of or corrosion on electrical connector terminals, pinched or chafed wiring, etc. You can see these circuits and connector locations in the Electrical Guide, which you can download here:
Jaguar S-Type Electrical Guide 2005
Also, please visit the New Member Area - Intro a MUST and post a required introduction so we can learn something about you and your Jaguar and give you a proper welcome.
Cheers,
Don
Old May 7, 2018 | 01:02 AM
woox4's Avatar
Sifiso has an S-type...
Old May 7, 2018 | 05:40 AM
JagV8's Avatar
Help yourself by posting in the S-Type section
Old May 7, 2018 | 06:10 AM
Welcome to the forum Sifiso Michion Radebe,
I've copied your question from another similar thread in X350 forum to S-Type forum. This is the pace to post technical questions about your model.
Old May 7, 2018 | 06:14 AM
Welcome to the forum Sifiso,
I've copied your question to S-Type forum for advice from members with the same model as yours. Here's the link to it:
https://www.jaguarforums.com/forum/s...7/#post1890637
Please use that thread and NOT this one here in X350 forum.
Dale Dunn
Oct 21, 2016 01:49 PM
S Daddy
Oct 15, 2016 04:24 PM
JB73
Oct 2, 2016 05:22 AM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Nov 20, 2006 10:55 PM
