Found some problems with my new purchase
Old Feb 19, 2012 | 10:55 AM
cel2620xl's Avatar
Default Found some problems with my new purchase
Hi
I'm a newbie and i just purchase an 04 jag St with 108k and i notice a few problems .
1 My center console were the cup holder are located i can't lift the center piece to access the dc jack.
2 when i lock the the door the rear passage and rear driver door locks and unlock itself continually then stays unlock
3 My airbag light came on. i was reading the manual dose the have to do with the passage side not have any body siting in the seat.
rick
Old Feb 19, 2012 | 02:49 PM
Jayt2's Avatar
Veteran: Navy
Active Streak: 30 Days
First thing.....check your battery, if it's the original, it may be on the way out. Get a hygrometer from a local auto store and check each cell.
Also, if it is original, just replace it, it's probably on it's "last legs".
Those problems just may clear up.
Good luck...
Old Feb 19, 2012 | 06:18 PM
Try this for the console https://www.jaguarforums.com/forum/s...ing-car-62801/
Old Feb 19, 2012 | 11:19 PM
NBCat's Avatar
Does the vehicle display any codes or is the 'check engine' light (MIL) on?
Old Feb 20, 2012 | 01:50 AM
JagV8's Avatar
Door lock is probably the lock/microswitch. Search will get you other people's fixes or if needs be try Jaguar Forum.co.uk • Index page as it affects some people here too.
Old Feb 20, 2012 | 07:55 AM
carelm's Avatar
The airbag warning light might be due to a loose connection in the wire that's under the seat. Try to reach under the seat and jiggle a 1/4" wire that's in the middle of the seat area.
Old Feb 20, 2012 | 10:35 PM
cel2620xl's Avatar
Good luck...
I can't say if it a original battery, but what i can say about the battery is interstate batteries. if that help. sorry for the late reply. please let know how to solve this problem,
Old Feb 21, 2012 | 02:41 AM
JagV8's Avatar
Probably best just to follow the advice you quoted.
Old Feb 21, 2012 | 02:05 PM
cel2620xl's Avatar
forward..............
Old Feb 21, 2012 | 05:38 PM
cel2620xl's Avatar
Originally Posted by cel2620xl
Im gonna run to autozone and get OBDII scan and then ill find out what going on with the car. My last concerns is i wanna put some new shoes currently i have 17" an i wanna put 20". can some tell what the offset and the bolt pattern please?
i just came back from autozone and i got the follow-in error codes :
P1549
p1646
p1000
The only thing is the sale-men could't tel me what the errors meant.... please help
so far i google the error code an this what i got
P1549 - Manif. Cntrl. Veh. Spd. Idle Speed Control Auxilary Inputs
(pending) P1000 - Manif. Cntrl. Veh. Spd. Idle Speed Control Auxilary Inputs
(pending) P1549 - Manif. Cntrl. Veh. Spd. Idle Speed Control Auxilary Inputs
P1646 LINEAR O2 SENSOR CONTROL CHIP
Old Feb 21, 2012 | 06:18 PM
joycesjag's Avatar
Norri, on the P1549, alldata is calling it the "top" circuit IMT not the (bottom) circuit IMT. (HHmmm)
cel26.... you may be asking what and where is an IMT, look here:
https://www.jaguarforums.com/forum/s...ck-pics-49214/
and here:
https://www.jaguarforums.com/forum/s...ics-faq-32135/
Possible the wiring is disconnected or chaffed, could be the IMT O-rings need to be replaced. If they are bad it could be a cause for the P1646. So I would change the IMT O-rings and see if that clears up the codes listed.
edit: and cel26... please put your vehicle details in your signature, it will only help us help you in the future!
goto "User CP" click on "edit signature"
Old Feb 22, 2012 | 02:05 AM
JagV8's Avatar
The codes PDFs are in JTIS and here in the FAQs. Do not rely on google etc UNLESS you are 100% certain you are finding a code for your make, engine, year car as you can be going down the wrong route - looking for a fault that does nto apply to your car! Your P1000 is an example.
Summary: use the proper jag codes PDF / JTIS. Tells you what the causes can be, too.
On the 20", I'd fix the car first and see what $$$ you have left after that.
Old Feb 22, 2012 | 07:33 AM
Copied from JTIS
P1549 V6 EMS
OBD II
IMT valve 1 (bottom) circuit
malfunction
Battery voltage > 12 volts
Start engine and bring to
normal operating temperature
> 82 °C (180 °F)
Run engine at 5000 rpm in N
for 20 seconds
2 N ECM Default:
– IMT 1 Inhibited
PI1
-038
IMT Valve 1 (bottom) disconnected
IMT Valve 1 (bottom) to ECM drive circuit fault
IMT Valve 1 (bottom) power supply circuit fault
IMT Valve 1 (bottom) failure
P1646 EMS
OBD II
ECM HO2 Sensor control
malfunction –
bank 1 upstream (1/1)
Drive vehicle for 10 minutes 2 N ECM Default:
– HO2S 1/1 control circuit
inhibited
— HO2 Sensor 1/1 heater failure
HO2 Sensor 1/1 sensing circuit:
short circuit to ground, short circuit to
high voltage, open circuit, high resistance
ECM Failure
Old Feb 22, 2012 | 08:45 AM
JagV8's Avatar
codes PDF I have says
(top)
Now puzzled!
Even the newer one from TOPIX (ref JTP 10371) says top.
Old Feb 24, 2012 | 05:05 AM
cel2620xl's Avatar
Originally Posted by Norri
Copied from JTIS
P1549 V6 EMS
OBD II
malfunction
> 82 °C (180 °F)
for 20 seconds
2 N ECM Default:
– IMT 1 Inhibited
PI1
-038
P1646 EMS
OBD II
malfunction –
inhibited
ECM Failure
Thank you is it possible you can give me a pic where the sensor located please. im referring to HO2 Sensor 1/1 heater failure
Old Mar 4, 2012 | 11:38 AM
cel2620xl's Avatar
Copied from JTIS
P1549 V6 EMS
OBD II
malfunction
> 82 °C (180 °F)
for 20 seconds
2 N ECM Default:
– IMT 1 Inhibited
PI1
-038
P1646 EMS
OBD II
malfunction –
inhibited
ECM Failure
HI again, I sorry to bother you but i don't understand please explain!!!!
Old Mar 4, 2012 | 12:24 PM
joycesjag's Avatar
P1549 is indicating there is a problem with the upper IMT valve. The most common failure is a yellow O-ring that fails and allows for a vacuum leak. There are new improved green O-rings that should be used.
Look here for checking it, btw there are 2 IMT valves. Within this link there is another link for replacing the IMT O-rings.
The P1646
is stating that the upper H02 sensor is failing, it might be caused by the faulty IMT valve. I would get the IMT vavle checked out and then see if the P1646 code clears.
The HO2 sensor is located beneath the vehicle and above the Catalytic Converter on the exhaust pipe manifold side.
Old Mar 4, 2012 | 04:32 PM
(top)
Now puzzled!
My JTIS (downloaded from here) says P1532 is the top IMT and P1549 the bottom.
Alldata tells me the opposite. Looks like the JTIS is wrong. Is it?
Old Mar 4, 2012 | 05:32 PM
JagV8's Avatar
The TOPIx one is much newer than JTIS so I reckon JTIS is wrong.
Old Mar 4, 2012 | 06:47 PM
joycesjag's Avatar
I would just venture to guess that it would be the lower (bottom) IMT that is failing, only because thats the one that has the oil pooling in the port. But if the O-ring failed on the top IMT hmmm(?).
Maybe a new flaw between Topix, JTIS and Alldata (?).
For the few years I've been here, I cannot recall an actual IMT Valve failing, only the O-ring.
